Hd500 Edit Keeps Turning Amp Off?
4 replies to this topic
#1 innovine
innovine
    Iknowathingortwo
  • PipPip
  • 322 posts
  • Registered Products:2
Posted 26 February 2014 - 11:06 AM
 I noticed recently that HD500 Edit keeps toggling the amp model off every time I do something... for instance, if I drag an effect to move it from one position to another, when I release it, there is a quiet crackle from the amp, and the amp model turns off. I can turn it back on just fine, but it'll turn it off again next time I move a pedal/effect..
I'm using HD500 with my pod 500hd while it's connected to my DT25 via line6 link, which is NOT currently connected via midi.  This problem only came up recently and I'm damned if I can think of what I might have done to cause it...
#2 radatats
radatats
    Power User
  • PipPipPipPip
  • 2323 posts
  • LocationOrange County, NY
  • Registered Products:3
Posted 26 February 2014 - 01:18 PM
yeah this is a consistent occurence when I have my DT connected too.  I am not sure what causes it but it does not happen without the DT connected...
#3 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2329 posts
  • LocationU.S.A.
  • Registered Products:17
Posted 26 February 2014 - 01:57 PM
Same thing happened to me a few times, then I adjusted my method of building and using patches. The noise can surprise you enough to make ya JUMP.
#4 innovine
innovine
    Iknowathingortwo
  • PipPip
  • 322 posts
Posted 26 February 2014 - 01:58 PM
*facepalm*
#5 sonic
sonic
  • 43 posts
  • LocationHaacht, Belgium
Posted 27 February 2014 - 11:29 AM
Same thing here... It happens when I start a patch from scratch and the selected amp switches off as I move an effect. The workaround is to save the patch intermediate. Also when I had a volume pedal set to go from 70% to 100% and I switched to another patch to check the levels, when I came back the volume pedal was reset to 0%. Again saving the patch first resolved the issue.
  • 1
Sammy
Line6 DT25 head and cab, Line6 HD500, Line6 JTV 59.
Marshall JVM 410H, 1960 AX cab.
Gibson SG Standard.
Steinberger GM 4S (Newburgh).
