Complex Setup With Pod Hd Pro - Check Safety
pod hd pro reamp dry out pedalboard preamp head
4 replies to this topic
#1 evovch
evovch
  • 3 posts
  • Registered Products:1
Posted 27 February 2014 - 07:10 AM
Hello. collegues,
I just wonder if setup like this is safe from electrical point of view.
Attached File  Guitar_reamp_scheme.png   47.42KB   0 downloads
I just want to tweak a little bit the knobs, compare the sounds.
Also this will allow to have several purpose setup at the same time:
You can play and record using POD HD Pro sound,
You can reamp from PC,
You can play and record using all external hardware.
Thank you!
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 8796 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 27 February 2014 - 08:17 AM
Well, you probably know this, but just make sure you either have speakers connected to the head or have the "Power Soak" set to mute on that H&K head. Other than that, there isn't anything electrically from a safety perspective you'll have to worry about. With interconnecting all this equipment, though, it may be likely you could run into ground loop issues.
#3 ColonelForbin
ColonelForbin
    Power User
  • PipPipPipPip
  • 1671 posts
  • LocationChicago, Illinois
  • Registered Products:7
Posted 27 February 2014 - 08:49 AM
To split your signal, be sure to use no mono FX blocks in the PRE amp position of the HD500. Pan the two channels hard left and right in the 'mixer' on the HD500. In the HD500, for routing purposes, assign channel one to guitar only, and assign channel two to XLR in only. When you send that signal via USB to the computer, you should be able to arm your recording software with two mono tracks, and assign the left HD500 to one track and the right HD500 to a second track.
When placing mono fx blocks in the pre-amp position, all signals are merged. When there is a stereo fx block or none in the pre amp position, the two channels are left separated.
-----from the manual-----
Page 3, Setup: Input Options
Input 1 and Input 2 Source (Knobs 1 & 2) - Select the physical input(s) that you want to be the “source” fed into the signal path. Note that you can choose different Sources to independently feed each signal path, or choose Same to feed a common Source into both paths.
About Source Input Signal Routing:
It is important to note how POD HD500 actually routes Source Inputs 1 and 2 through Amp & FX Blocks that are positioned “Pre” position. The following behaviors apply:
• In a configuration with no Amp or FX Blocks in Pre, Input 1 is fed only to Path A and Input 2 only to Path B. Therefore, this is the best configuration if you want to retain discrete Input Sources into Paths A & B.
• Placing an Amp Block or an active mono FX Model in Pre results in a “mix-down” of Input Sources 1 & 2, feeding the same, combined signal into each Path A & B.
• Placing a Stereo FX Model in Pre results in the left channel FX output being fed to Path A and its right output to Path B.*
• The Mixer Block’s Volume and Pan options provide independent control for Path A & B outputs before they are fed through any Blocks positioned “Post” the Mixer.
• By setting Input 2 to “Same,” this effectively routes your Input Source to both stereo Paths A & B (which is how you can feed one guitar input into two Amp Models and/or parallel FX, for example).
Model Types and Mono/Stereo Signal Routing
It is important to note that some Models (all EQs, Wahs & Volume, and some Modulations, Filters, Pitches and Delays, as well as the FX Loop) preserve a stereo output within the signal chain, while others (all Dynamics, Distortions, all Amps & Preamps, and other various Models) are mono FX and do not. The POD HD500 Inputs 1 & 2 are fed into the signal chain as stereo (see “Page 3, Setup: Input Options” on page 2•4).
Therefore, wherever a mono FX or Amp Model is inserted, the Left & Right channels of this stereo signal is “mono-ized” and heard as a two-channel mono signal at the Model’s output. To follow are a few examples:
Ping
#4 evovch
evovch
  • 3 posts
Posted 27 February 2014 - 08:50 AM
Thanks, Phil.
So, there is no problem in creating a chain loop?
Line6 -> Reamp -> Pedals -> Amp -> Line6
As for power soak it is absolutely clear.
#5 ColonelForbin
ColonelForbin
    Power User
  • PipPipPipPip
  • 1671 posts
Posted 27 February 2014 - 09:46 AM
+1 to the ground loop comment, if possible make sure everything is plugged into the same outlet / power strip.
For "reamping" again, just be sure your signal paths are divided, or you will end up feeding the XLR / mic signal and the source guitar dry signal into places you don't want them to be merged.
Even though you are sending the dry out (a nice feature upgrade on the Pro over the floorboard), you still want to assign the guitar in and the XLR in as two seperate signals. Not sure the specifics on how the HD desktop handles the dry out when you have multiple inputs connected. I would guess it's dedicated to the guitar signal, but I would double check the manual on that.
Here is a thread discussing wet and dry recording:
http://line6.com/sup...-with-my-hd500/
Thread from the archive about re-amping:
http://line6.com/sup...ew/thread/87448
Also tagged with one or more of these keywords: pod hd pro, reamp, dry out, pedalboard, preamp, head
