X3 Live Exp Pedal Only Works In Safe Mode
expression pedal safe mode x3 live
2 replies to this topic
#1 Lordmore
Lordmore
  • 2 posts
  • Registered Products:2
Posted 27 February 2014 - 10:55 AM
Hi there.
I couldnt find an answer to my problem on the web so im asking here now.
My X3L's expression pedal stopped working. Since im out of warranty, i opened it and checked for solder problems and also cleaned the sensors, all seems fine.
Then i rememberd that theres the Safe Mode with pedal calibration, so i fired it up and to my surprise the pedal worked, as in i was able to calibrate it (it goes smoothly from 0-255) and it also showed the "P" for passed settings (i think?)
However, it doesnt do a thing in normal mode, neither in Wah, Volume nor Tweak mode. It also doesnt switch the Wah/Vol LEDs when using the toe switch, but im not to sure if it even does that in the first place since i only use it in Tweak mode.
I already tried it with factory resets + firmware rollbacks.
I dont really know what else i could try.
Do i have to save/apply the changes i made in Safe Mode, appart from saving the calibration itself with the D stomp knob?
Would be nice if someone could suggest anything, or maybe even had this problem before and solved it.
Thanks.
#2 featherrun
featherrun
  • 2 posts
  • Registered Products:1
Posted 31 May 2014 - 07:22 PM
ME TOO !SOMEBODY tell me WHY ~~~
#3 featherrun
featherrun
  • 2 posts
Posted 01 June 2014 - 06:29 PM
I like your question, you can put a similar tone into tone1 and tone2, then open the double tone, then pedal can work, but only one tone at work. I guess that is where the software is wrong, no way, only this first with it.
Also tagged with one or more of these keywords: expression, pedal, safe, mode, x3 live
