Fbv Express As Dt25 Controller
5 replies to this topic
#1 chrishlp
chrishlp
  • 33 posts
  • Registered Products:3
Posted 27 February 2014 - 01:52 PM
Anyone used the FVB Express Mkii pedal as a MIDI controller to change between channels A/B and select Voicings on the DT25/50?
Looking at the manual, this should work using a USB to MIDI cable and the LIne 6 FVB edit software.
Chrislp
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17728 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 27 February 2014 - 01:58 PM
you're reading the manual all kinds of wrong... no way that works without doing some serious engineering.
the FBV edit program only works with a computer...
#3 chrishlp
chrishlp
  • 33 posts
Posted 27 February 2014 - 02:05 PM
If so that is a shame, Line 6 should provide a contoller for the DT amps especially now you can have the 8 preset tones.
You can get USB to MIDI cables and the edit sotware runs on MIDI control CC parameters, are you 100% certain it does not work??
#4 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17728 posts
Posted 27 February 2014 - 02:20 PM
you can't get MIDI out of the FBV pedals... its a digital signal...
that and if you think you have "8 preset tones" you very much do not understand the DT amps...
not to mention... if you're controlling it entirely by midi... there's no limit to how many "tones" you could configure...
(other than whatever limits you would have on your midi controller)
again... i highly advise against this.... because there are so many things you CAN'T control via midi... mainly the volumes etc...
that you'd blow your eardrums switching around....
best to accept it as a 2 channel amp...
just use a pod if you want any more control than that.
  • -1
#5 chrishlp
chrishlp
  • 33 posts
Posted 28 February 2014 - 02:29 PM
With all respect, have a look at the Line 6 software for the FBV. It is definately MIDI and the manual talks about using it as a MIDI controller for various software packages.
#6 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17728 posts
Posted 28 February 2014 - 02:39 PM
yes... for SOFTWARE packages on the computer VIA a USB connector... (you didn't mention using a computer... you wanted to use it with a DT amp)
it does not output midi.... as in direct out to a midi cable that you could plug into a midi device... sorry if that was unclear...
the output of the FBV pedal is a proprietary RJ45 cable that transmits midi digitally to line6 devices that accept an FBV connection... not to ones that do not have an FBV connection... such is the case for the DT amps.
