gary9605 Posted March 3, 2014 Share Posted March 3, 2014 "Most" times when i start my computer (Win 7) then plug in my UX2 then start Pod Farm....... the needles spike then reset to about 3/4 scale, and i get a lot of distrotion and feedback. Start stop Pod farm , same results Unplug and reconect same results. Reboot and reconnet same resluts Have loaded most current drivers from the Monkey ( in fact did that after on really bad day....and it seemed to work fine) but... back to same issue. Then.... every so often.... it just all works. Looking for some ideas........ Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted March 4, 2014 Share Posted March 4, 2014 I have heard of some people saying the same thing, and it is usually because the default patch that comes up in PF is one with huge amount of gain/distortion. Quote Link to comment Share on other sites More sharing options...
gary9605 Posted March 4, 2014 Author Share Posted March 4, 2014 No....... pretty sure that is not the issue. I"ve made changes to the "last" used setup, so when i open PF it is with a different setup than before...... same thing happens. Also..... that would seem to not address the few times that it does seem to work. My suspiction is that maybe i have a bad USB port....maybe a broke solder joint. OTherwise, i suspect that is some Win 7 / sound system / thing that is starting and adding the distrortion....just not sure how to pinpoint that. Whick i hope is the case, and once i'm pointed to it, i can correct it. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted March 5, 2014 Share Posted March 5, 2014 How about leaving your UX2 plugged in, then starting the computer? Obviously try a different USB port, too. Quote Link to comment Share on other sites More sharing options...
gary9605 Posted March 5, 2014 Author Share Posted March 5, 2014 FFLBRGST thanks for your replies....... yes, i've tried it plugged in first and, unpluged till after boot up, aso, front and back USB ports..... get same results. Good news is.....last night, no changes made on my end. This morning.....not so much Just seems to be intermitent... but anoying. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted March 6, 2014 Share Posted March 6, 2014 That sounds like a driver problem, try uninstalling them, delete all the files from the 'Line 6' folder (uninstalling doesn't delete them), then redownload them an dinstlal them again. Quote Link to comment Share on other sites More sharing options...
