MGblade Posted March 4, 2014 Share Posted March 4, 2014 hi i have a brunetti xl r-evo wich i run my 500x by 4cm. i want to control the amp channels by midi with the 500x instead of the amps footswitch. i'm a midi noob so any help is appreciated, this is wat the amps manual says: "the MIDI system receive in "OMNI" mode to store channel: 1) select the preset on you're midi footswitch. 2) push and keep the button switch on the front pannel for about 6 seconds till the leds blink" step1 and 2 i get, but what i want to know is wich message type i have to program within HD EDIT to change the channels etc. grts Marcel Quote Link to comment Share on other sites More sharing options...
MGblade Posted March 4, 2014 Author Share Posted March 4, 2014 ! Quote Link to comment Share on other sites More sharing options...
MGblade Posted March 5, 2014 Author Share Posted March 5, 2014 anyone?? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted March 5, 2014 Share Posted March 5, 2014 you'd need to refer to your amp documentation for that. step1 and 2 i get, but what i want to know is wich message type i have to program within HD EDIT to change the channels etc. grts Marcel Quote Link to comment Share on other sites More sharing options...
MGblade Posted March 5, 2014 Author Share Posted March 5, 2014 There is nothing more in the amps documentation, it receives in OMNI mode and the two steps, thats all. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted March 5, 2014 Share Posted March 5, 2014 no midi expert... but have you tried installing midi-ox, open the monitor window, and then switch channels on the amp? perhaps it will show you some midi activity that you can use? maybe not... and might be a bit of effort for no result... but i'm not aware of any universal type commands.... although you could always search and see what mesa/marshall/etc use and that might point you in the right direction. Quote Link to comment Share on other sites More sharing options...
MGblade Posted March 14, 2014 Author Share Posted March 14, 2014 no midi expert... but have you tried installing midi-ox, open the monitor window, and then switch channels on the amp? perhaps it will show you some midi activity that you can use? maybe not... and might be a bit of effort for no result... but i'm not aware of any universal type commands.... although you could always search and see what mesa/marshall/etc use and that might point you in the right direction. thanks!!! managed to work it out , i use the "program change" mode, works great!! the pod saves the midi settings per bank, but my plan was to create different patches for each channel and use fs 5,6,7,8 for channel changing in abcd mode A+B clean channel C boost channel D lead/solo channel so i can use different effects for each channel, but the pod doesn,t spillover effects between patches :wacko: am i wright?? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted March 14, 2014 Share Posted March 14, 2014 That's correct, it would take double the processing (DSP) to spillover, because you'd need to process both the previous and the current tone at the same time. thanks!!! managed to work it out , i use the "program change" mode, works great!! the pod saves the midi settings per bank, but my plan was to create different patches for each channel and use fs 5,6,7,8 for channel changing in abcd mode A+B clean channel C boost channel D lead/solo channel so i can use different effects for each channel, but the pod doesn,t spillover effects between patches :wacko: am i wright?? Quote Link to comment Share on other sites More sharing options...
MGblade Posted March 14, 2014 Author Share Posted March 14, 2014 That makes sense, a bit disapointing though, i only use delay, reverb, chorus, overdrive per patch. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted March 14, 2014 Share Posted March 14, 2014 you can "enable" spillover, to work with the effects loop... so if you put a delay or whatever in the loop it will allow spillover. (it basically mutes the loop input and allow the output to remain on.) extra complication... but an option is better than no option. Quote Link to comment Share on other sites More sharing options...
MGblade Posted March 14, 2014 Author Share Posted March 14, 2014 mm oke, a extern delay pedal i supose Quote Link to comment Share on other sites More sharing options...
