Dt25/hd500 Acoustic Tone
dt25 hd500 dt25/hd500
2 replies to this topic
#1 drschultz
drschultz
    Iknowathingortwo
  • PipPip
  • 117 posts
  • Registered Products:3
Posted 07 March 2014 - 11:54 AM
Hello all, I just created a new acoustic patch for my DT25/HD500 setup.  I borrowed from the "Wide Acoustic" patch included in the HD500.  Made some changes and think it sounds pretty good.
Check it out and let me know what you think.
http://line6.com/cus...ne/tone/271639/
#2 ColonelForbin
ColonelForbin
    Power User
  • PipPipPipPip
  • 1695 posts
  • LocationChicago, Illinois
  • Registered Products:6
Posted 07 March 2014 - 12:58 PM
I am offline right now, but I did load the patch in HD Edit, and I noticed you do not use an amp model for this patch.
It is worth noting that when using L6Link between the HD500 and the DT25, in single amp-block patches like this, when you do not choose an amp model, the DT will then default to whatever is defined on the actual DT amp in channel A - I think.
It may be worth verifying this behavior.
There are actually a few threads on here from people trying to get the JTV acoustic simulations to work properly. If you define two amp blocks, make amp B 'no amp', and then choose an amp for block A, but 'mute' it in the mixer (on the HD500) it should achieve what you are trying to do, which is bypass all preamp / amp models.
This thread by radatats: http://line6.com/sup...v-with-dt-amps/
I am in the middle of moving, so I am eager to get settled in the new house and get my studio room all set up! It may be a couple weeks though, before I can really dig in, so I have to live vicariously via others until then... :)
#3 drschultz
drschultz
    Iknowathingortwo
  • PipPip
  • 117 posts
Posted 07 March 2014 - 02:21 PM
I did some checking with the DT Edit program.  I noticed that the channel switched to B when there is no amp block.  I am connected via L6 Link.   Yes, whatever amp is set to channel B, voicing I on the DT will become the AMP.  I have set mine to NONE.  IMO it sounds good with the default blackface double.
Thanks for pointing this out.  I still think it sounds good.  Let me know what you find.
EDIT:  I tried placing an AMP block in A then an Empty one in B AND muting A.  This did not work for me.  I find the setting channel B to NONE in DT Edit gives me the best sound.
I posted a quick sample.  It is in four parts.
Part 1: Dry sound, HD500 to the DT25, No Amp block on either the DT25 or the HD500
Part 2: FS2 is on, EQs 3 and 4 in the chain
Part 3: FS2, FS3 and FS4 are on.  EQs 3 and 4, Chorus, and Delay
Part 4: Dry Sound again.
Sorry about the volume.
https://soundcloud.c...stic-patch-dt25
Also tagged with one or more of these keywords: dt25, hd500, dt25/hd500
