Line Inputs Recordings Failed Since 1.10 Update
Best Answer davec69 , 04 June 2013 - 11:39 PM
Success.  We were able to make a recording tonight of both the Main Outputs and the Line Inputs.
We tried a bunch of things, including deleting folders on the PC, re-formatting the SD card, and nothing helped.   The SD card wasn't being recognized by the M20d.
The fix for us was to create a brand new Setup from scratch.  I then added all of the instruments and microphones to the Stage again, did the usual auto trim.  After we did this, the SD card was recognized, and the recording was successful.
I have updated my support ticket with the steps that i went through.  Maybe someone smarter than me will chime and tell us what's going on.  All I can suggest is to try creating a new setup from scratch, if you are having problems with the M20d recognizing your SD card, or if your recordings are not working correctly.
Go to the full post
86 replies to this topic
#81 case67
case67
  • 49 posts
  • LocationSouthwest Germany
  • Registered Products:18
Posted 25 September 2014 - 02:30 PM
Try to open the 'no sound' files in program VLC.
There is a good chance that the recorded audio is in the files, but some header data is missing and
Windows Media Player and m20d won't play it. But VLC will.
I also had 'stopped' recordings.
Issue was the SD card. MicroSD with adapter from Transcend, class 10.
It was at maximum class 5 and had reproducible write errors.
I replaced it with a reliable card an everything is fine now.
#82 davec69
davec69
  • 85 posts
  • Registered Products:5
Posted 26 September 2014 - 09:30 AM
Just had this same thing happen on our bands last show.  Recorded the first part of the show fine.  Stopped the recording, and started to record the 2nd half of the show.  Afterwards, the first folder audio files came out fine.  The 2nd half of the show, I got all blank files.
There's actually audio there.  I've had luck in the past pulling up the audio in Sound Forge, by importing as raw data, and trying different import settings (bit rate, sample rate, ect) until I got it to work, but no luck this time.  Just lost the audio for the 2nd half of the show.  So frustrating.
Unfortunately, the M20D seems to be a dead product now. Doubt there will be any fixes.
#83 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17812 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 26 September 2014 - 09:46 AM
there is nothing to backup this statement.
in fact with my limited knowledge on the matter, i can without a doubt say that this is 100% false.
there is ALOT of life left in the stagescape mixers
#84 davec69
davec69
  • 85 posts
Posted 26 September 2014 - 11:14 AM
Likewise, I have seen nothing to backup your statement.   Do you have some news about the M20D that you would like to share?
Our band has owned the M20D since day one.  At least a couple years.  In that time, I've seen what?  One update to the operating system.
Check the forum, and you will find threads regarding bad Ipad connections, Random power off issues, blank audio tracks, intermittent sound, random sound loss, ect.   None of which has been addressed.
We really like our M20D, but unless you know something that we don't, this product seems to have been abandoned by Line 6 / Yamaha.
I'm sure they'll come up some great replacement idea for it, but we won't be biting next time.
#85 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17812 posts
Posted 26 September 2014 - 11:40 AM
Product managers do not comment on work in progress, and I'm not permitted to say anything that i would know on the matter.
I've made a generalized statement on the matter, I'm not in a position to say anything specific even if i knew anything specific.
you've made an assumption...
#86 m20dev_API
m20dev_API
  • 20 posts
Posted 10 November 2014 - 02:55 PM
@TheRealZap
Can you please be a little more specific? DO you know anything more specific? you said:
"I'm not in a position to say anything specific even if i knew anything specific."
Just wondering if you do know any info that everyone here is not privy to. thanks
#87 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17812 posts
Posted 10 November 2014 - 03:00 PM
I cannot be more specific, but i do know enough to make my previous statement.
if you have any current issues please contact support, if you just want "updates"... time will tell.
