Which Editing Software Do You Use On Recordings From The M20d?
software m20d presonus
Best Answer LDBecker , 17 March 2014 - 03:12 PM
Thanks so much to all who contributed to this question!  Helpful board!!
Digital-Sound - I was hoping you would chime in as I knew you were a Presonus user as well...
Still trying to get my head around it a little. With the Presonus board, the board itself is the recording surface and what you do there affects the files - which you are recording in and through the DAW. With the M20d, I guess you just load the files into the DAW.
Thanks again,all, for your input!
Larry
Go to the full post
7 replies to this topic
#1 LDBecker
LDBecker
  • 76 posts
  • LocationLos Angeles area
  • Registered Products:7
Posted 15 March 2014 - 05:33 PM
Just got my 2nd L3T to go with my JTV 69 and HD 500x... Traded in 2 Mackie 450v2s and an 1801 sub. I currently am using a Presonus 16.4.2 and got the Studio One Professional software to go with it...
Wondering if the files from the M20D can be edited by the Presonus software. I actually was able to do some nice recordings with it, and have some $$ invested in it, so as I think of going to the M20D I'm wondering if I also need different software.
Thanks!
Larry
#2 Digital-sound
Digital-sound
    Iknowathingortwo
  • PipPip
  • 418 posts
Posted 15 March 2014 - 05:47 PM
I also use studio one. As well, left over from my presonus days. It works well for me. Pretty much any of them will do the job, so if you are comfortable with studio one, you may as well continue.
Happy editing!
#3 bassman24
bassman24
  • 86 posts
  • LocationSouth West Germany
  • Registered Products:2
Posted 15 March 2014 - 11:16 PM
I'm using Logic :)
#4 SiWatts69
SiWatts69
    Gear Head
  • PipPipPip
  • 507 posts
  • LocationSouth Yorkshire, UK
  • Registered Products:13
Posted 16 March 2014 - 08:38 AM
MixCraft 6 Pro here :-)
Complete DreamStage:
M20d with 2x L3m, 2x L3s, 2x L2t & 2x L2m
XD-V75HH & XD-V75BP wireless
#5 case67
case67
  • 49 posts
  • LocationSouthwest Germany
  • Registered Products:18
Posted 17 March 2014 - 03:13 AM
Ableton Live 9 Suite. Just because i already had it.
The files recorded on SD card are standard 24 bit/48 kHz .wav format,
so every serious DAW should be able to handle that.
Kind regards,
 Tom
#6 ColonelForbin
ColonelForbin
    Power User
  • PipPipPipPip
  • 1667 posts
  • LocationChicago, Illinois
  • Registered Products:9
Posted 17 March 2014 - 01:05 PM
I've been wondering the same thing. I've been using Adobe Audition for a while now; but just recently made the leap to ProTools 11. I am definitely up against a steep learning curve! I guess there is something to be said for shaking up the comfort zone on these types of things.
But yeah, the 24/48 is pretty standard. I know, at least with Adobe Audition, that when I record 24/48 with my Tascam, I end up having to save them out as some kind of 32 bit, so it can write a .pk file, which allows to quick load into saved sessions. Not sure how other software handles that kind of thing; and quite frankly, not entirely sure what the difference is, nor do I know how the M20d handles the .wav files it saves; likely similar to what my Tascam does, though I can't yet confirm that.
#7 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15697 posts
  • LocationOntario, Canada
  • Registered Products:15
Posted 17 March 2014 - 01:27 PM
I have used both Reaper and Cakewalk (Sonar-light) with M20d-produced WAV files. No problem. I agree with case67 - any reasonable DAW will handle the files.
But I haven't tried manipulating the WAV files in a DAW and then attempting to export them in WAV format back onto the SD card for playback through the M20d again. I doubt that would work; the M20d would likely not accept any wav files that it did not produce - but that's just my guess. Once things are in the DAW they likely have to stay there.
.... John Lennon
#8 LDBecker
LDBecker
  • 76 posts
Posted 17 March 2014 - 03:12 PM   Best Answer
Larry
Also tagged with one or more of these keywords: software, m20d, presonus
