Dynamics (& Larry Carlton)
tone larry carlton
9 replies to this topic
#1 nikoniablue
nikoniablue
    Iknowathingortwo
  • PipPip
  • 102 posts
  • LocationSt Albans, England
  • Registered Products:2
Posted 16 March 2014 - 03:32 AM
I'd like to build a patch for a DT25 and HD500 combo that really maxes out the responsiveness, so that I can use how hard I play on the guitar to balance a gentle clean tone with quite a full distortion for single lines.  A bit like Larry Carlton does - where his amp is highly responsive to his playing dynamics.  Any suggestions of starting points for amp & other settings?  I'm playing a Gibson Midtown Custom by the way which has Burstbuckers (PAF style humbuckers).  I do have a JTV-59 but it's a bit unreliable.  I'm not really trying to copy Carlton's tone, more wanting to get the most from that technique.  Thanks in advance for your ideas...
#2 malnack
malnack
    Iknowathingortwo
  • PipPip
  • 105 posts
  • LocationOmaha, Nebraska
  • Registered Products:10
Posted 17 March 2014 - 09:45 AM
My main patch does this for me. I have a HD500, DT25, and a JTV-59P. I believe I started with the AC30 type preamp. I think changed the cabinet and mic on it until I got what I was looking for. For the guitar model, I mainly use the Tele. If I dial back the volume control on the JTV about 15%, I get a really nice clean when I play lightly. The further I dig into it the more natural breakup I get. There are a couple songs in our set that I use this to my advantage, clean and quiet in the verse, a bit more bite in the chorus and full out attack by the end.
I'd be happy to share my patch. I'm at work right now so I don't have access.
#3 stumblinman
stumblinman
    Gear Head
  • PipPipPip
  • 882 posts
  • LocationPacific Northwest
Posted 17 March 2014 - 11:34 AM
Mic choice has no impact when connected via L6 link to a DT amp for future reference. Cabs do, but mic emulation is only enabled in studio/direct mode, so that should help eliminate one variable. I messed with them a lot when I first got my Pod until I was told the same thing.
#4 malnack
malnack
    Iknowathingortwo
  • PipPip
  • 105 posts
Posted 17 March 2014 - 11:44 AM
Thanks! Wasn't aware of that.
#5 nikoniablue
nikoniablue
    Iknowathingortwo
  • PipPip
  • 102 posts
Posted 18 March 2014 - 12:51 AM
I'd be interested to see the patch.  Thanks
#6 ice9mike
ice9mike
    Iknowathingortwo
  • PipPip
  • 152 posts
  • Registered Products:3
Posted 18 March 2014 - 07:30 AM
Definitely start with the AC30 as it is class A and has the most dynamics. I have a tube driver boost in front of it to make sure it breaks up when I play harder.
You could also try switching a marshall plexi or jtm 45 to class A and see how that works out.
#7 malnack
malnack
    Iknowathingortwo
  • PipPip
  • 105 posts
Posted 18 March 2014 - 05:14 PM
Here is the current version of my tone. I guess I switched the preamp about a month ago. I do have the previous AC30 based one as well. Give this a try and remember to dial your volume back about 15-20%.
http://line6.com/cus...ne/tone/275611/
I've assigned a Chorus to 1, a Delay to 2, a tube overdrive to 3, and a swell to 4.
#8 chrishlp
chrishlp
  • 33 posts
Posted 19 March 2014 - 03:19 PM
Try the gibson EH-185.  It runs Class A so tends to be responsive.  I run full model sims from my HD500 and adjust the sim drive and master volume to get the right balance between preamp drive and power amp saturation.  Have a play around with the sag control as well.  Goes great with a strat!
#9 nikoniablue
nikoniablue
    Iknowathingortwo
  • PipPip
  • 102 posts
Posted 20 March 2014 - 09:25 AM
Yeah - tried it and liked it - thank you.  Prefer it with the AC30 TB Pre rather than the J45. I set it to my taste with about 65% drive.  Yummy!
Thanks to Chris also for suggestion of the EH185.  Not as responsive as the Vox but a good sound nevertheless. I don't think its possible to use the sag control with the Pre only settings I like to use with the DT25 unfortunately.
Forgot to mention, the Treadplate is actually very responsive if you keep the volume and gain backed off a bit.
#10 malnack
malnack
    Iknowathingortwo
  • PipPip
  • 105 posts
Posted 20 March 2014 - 09:42 AM
Thanks! I can't remember why I switched away from the AC30. I'll have to try that version again. I really love the breakup in it and when I need the crunch using the Les Paul model with the overdrive activated is just what I need. What is strange is that at our rehearsal volume (which is fairly loud), the level sounds about right when I engage the overdrive (FS3). However, at our last gig when I hit the overdrive it seemed significantly louder. It kinda freaked me out as I felt like I was blowing out the rest of the band.
Also tagged with one or more of these keywords: tone, larry carlton
