M13 Temp Synced To Protools Session Midi?
m13 tempo midi m9 m5 protools daw bpm session
1 reply to this topic
#1 Wokbar
Wokbar
  • 2 posts
Posted 16 March 2014 - 08:16 PM
I like the sound coming out of my amp with my m13, with a good mic it records well.  I would like to know if it is possible to have the tempo on the m13 controlled by my daw so everything jives in my session.
can I connect the m13 to my interface (rme ucx) and have the temp controlled this way?
I love the idea that the bpm in my protools session would match my m13.
#2 rboylee
rboylee
  • 1 posts
  • Registered Products:1
Posted 20 March 2014 - 09:01 PM
Hey Wokbar,
I love my M13, too! The answer is yes. If you don't already have the advanced users guide for the M13, do a search and download the PDF - There is an abundance of different MIDI Automation one can do with a DAW.
You should be able to use a MIDI cable accessory like this breakout cable, if it's the correct model I looked up.
I don't have ProTools, but I use the following:
  • Reaper
  • Windows XP 32bit
  • MIDIOX (Used for MIDI monitoring and troubleshooting)
  • MIDISPORT 4x4
Once my MIDISPORT is connected I can manage the ports in my DAW such as enabling them.
Within my DAW I inserted a MIDI track that outputs to the proper port connect to my M13.
Using the M13 users guide I created a MIDI item and used these parameters: CC# 64 @127 (Tap Tempo - 2 taps determine tempo)
Placing duplicate messages at quarter note intervals.
When you play the track, this will now "Tap in" the BPM. You may wish to put more than 2 taps or even copy/paste several more.
I love rehearsing a song in my DAW and slowing it down however much I need to and my tempo on my M13 is right there and my time based effects are synced up.
You can do much more than just tempo match, such as push a previously back up scene to your M13.
I am about to embark in some live automation as we currently use Ableton Live with a click during our worship sets. Having multiple MIDI devices such as keys and other multi-effects guitar effects (Line6) already could benefit from a little work up front.
I hope this helps you.
Also tagged with one or more of these keywords: m13, tempo, midi, m9, m5, protools, daw, bpm, session
