Midi Control Of Drive, Volume, Bass, Treble And Mid And One Other Midi Question.
10 replies to this topic
#1 MAP70
MAP70
  • 21 posts
  • Registered Products:3
Posted 18 March 2014 - 01:53 PM
Hi Guys, I Just got my DT50 and have been fooling around with the MIDI part of it. I have downloaded the MIDI Implementation guide and I have a few questions:
1) When controlling Drive, Volume, Bass, Treble and Mid how can you determine where the 0-127 is on the dial. I assume 0 is 0 and 127 is Full. Anyone have any ideas where the rest of the dial is?
2) I am using a MIDI controller (SoftStep 2) to send the CC's. My idea is to keep all my clean stuff on channel 1 and all my dirty stuff on channel 2. So I will send a MIDI CC 19 to select the channel, then a MIDI CC 12 or 89 to select the amp model. Then I can select my additional settings (volume drive etc)..
Does there need to be any pause between the CC's, because it seems I have problems when I program one button to make all the changes and the amp actually changing the the way I want it... is there a limit to the number of CC's sent simultaneously?
Thanks!
Mark
#2 MAP70
MAP70
  • 21 posts
Posted 19 March 2014 - 03:02 PM
Anyone???
#3 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 19 March 2014 - 04:41 PM
most people here use pods with the L6LINK. of course there are a variety of users so someone may have something to ad...
but you'll need a bit of patience when asking specific and detailed questions.
#4 MAP70
MAP70
  • 21 posts
Posted 19 March 2014 - 04:56 PM
Just wondering if anyone saw it.. I am sure people are using MIDI, just figured maybe more were?? LOL
Hopefully someone will have an answer!
Thanks for the reply!
Mark
#5 radatats
radatats
    Power User
  • PipPipPipPip
  • 2326 posts
  • LocationOrange County, NY
Posted 19 March 2014 - 08:40 PM
good luck... I don't think there are many, if any, DT users that don't use a POD...  try this...
http://line6.com/sup...-the-dt50d-r129
#6 MAP70
MAP70
  • 21 posts
Posted 20 March 2014 - 07:58 AM
Seems like it.. I rather use my pedals than the pod.. Just figuring support may see this and help.. Trying to figure out if I can send multiple cc's to the amp at the same time to change the settings..
Still working on it with my midi foot controller manufacturer but I may need to speak to support..
Thanks
Mark
#7 radatats
radatats
    Power User
  • PipPipPipPip
  • 2326 posts
Posted 20 March 2014 - 08:57 AM
this is a USER forum... support does not generally provide anything other than advice on what new gear to buy...  I have seen a couple of Product Specialists beginning to reply to posts but don't expect any sort of detailed info...
#8 MAP70
MAP70
  • 21 posts
Posted 20 March 2014 - 09:28 AM
Nice to know.. I may just need to call them... Thanks
Mark
#9 jffranklin2000
jffranklin2000
  • 6 posts
Posted 05 April 2015 - 10:01 PM
Map 70,
Did you finally resolve this issue? I was planning on doing the same thingwith my 2 DT25s. ( with a different advanced midi controller)
J
#10 MAP70
MAP70
  • 21 posts
Posted 07 April 2015 - 04:39 PM
Hi, jfranklin... I did end up using one of these: http://www.famcmusic...ore/liquid-foot
You need to make sure it can send a bunch of CC commands...These controllers are ricey but they seem to be one of the few that can do what I need for the DT50..
Mark
Map 70,
J
#11 jffranklin2000
jffranklin2000
  • 6 posts
Posted 07 April 2015 - 05:03 PM
Hi M,
Thanks for responding to an issue that happened a year ago. I ended up buying the mastermind GT. I can send 20 CC's. So I would assume that I'll be able to do whatever I need the DTs to do on top of everything else that I have. Have you encounterd any other issues controlling the DT's through midi alone? I'm setting up a stereo setup with 2 DT25's
Thanks.
