gennation Posted March 22, 2014 Share Posted March 22, 2014 I want to plug my POD 2.0 device into the L/R line inputs of the UX1 and hear it/record it on my computer through USB directly in my recording software. It seems the only way I can get sound from it is with the POD Farm software running. Isn't there a way to use it without POD Farm? I thought this was just a USB audio interface. Please confirm so I don't waste anymore time on it, thank you. Quote Link to comment Share on other sites More sharing options...
Triryche Posted March 23, 2014 Share Posted March 23, 2014 (edited) There is no optimal way while using the ASIO driver.. The UX becomes your sound card. You might be able to select a different driver in your DAW and turn on monitoring, but you will likely hear too much latency. Or just plug headphones into your POD 2.0 Edited March 24, 2014 by Triryche (strike out) Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted March 23, 2014 Share Posted March 23, 2014 you should be able to do what you want, really... the toneports and pod studios work just fine without pod farm. just make sure that you select the right input in the track on your DAW, and that your speakers are plugged into the toneport. Quote Link to comment Share on other sites More sharing options...
Triryche Posted March 23, 2014 Share Posted March 23, 2014 Zap, the DAW will capture, but the inputs are not routed to the analog outs or headphones without PF open. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted March 24, 2014 Share Posted March 24, 2014 if it's properly setup as your system soundcard it will. done it many times. Zap, the DAW will capture, but the inputs are not routed to the analog outs or headphones without PF open. Quote Link to comment Share on other sites More sharing options...
Triryche Posted March 25, 2014 Share Posted March 25, 2014 As Zap says, if it is set up correctly it will work. I had to go into the Windows mixer under recording devices and select listen to this device. But on my system the latency is too much for me. Quote Link to comment Share on other sites More sharing options...
