Recording Limits
recording
8 replies to this topic
#1 BucF16
BucF16
    Iknowathingortwo
  • PipPip
  • 263 posts
  • Registered Products:8
Posted 23 March 2014 - 01:45 PM
Recorded part of a gig on SD card last night.  I was playing and a buddy who's not as smart on the system was running sound so my info for the post is second hand.
Using a 64G SD card, freshly formatted, Made 3 recordings. One short test recording, then the first set, then the second and part of the third on a single recording.  In the third longer recording, the recording stopped and the sound man was unable to restart it. He was unable to relay the warning dialogue that the mixer gave him to me and I didn't find out about it until the gig was over so my info is somewhat incomplete.
Here's the data I have though.  I recorded all inputs and the main mix.  The SD card currently shows 44GB available, and 14GB used.
The first file is only 12 MB.
Second file is 3.6 GB and recorded no problem
Third file is 10.64 GB and is the one that kicked off
Largest individual track in the third file is 1.42 GB (the stereo mix).  I didn't get anywhere near the 4 hr limit.  Maybe 2 hr max on the third recording.
Any ideas on what could have gone wrong or what I can do to prevent it in the future?
As an aside, this was my third gig with the system and my band mates are for the most part blown away by the speakers.  Pretty sure they're all going to buy some more here pretty soon for their other band projects and also because they work so well with my system.
My old soundman has even broken down and put his Allen and Heath GL2400 up for sale.
#2 SiWatts69
SiWatts69
    Gear Head
  • PipPipPip
  • 506 posts
  • LocationSouth Yorkshire, UK
  • Registered Products:13
Posted 23 March 2014 - 02:44 PM
Simple really... stop trying to prove to be the exception to the rule.
Line6 quote class 10, 32GB capacity "SDHC" cards are the limit.
To have a 64GB card, you've got an SDXC card which, although some people seem to have gotten them to work, is almost always the cards that cause problems for people.
I have TWO SAMSUNG 32GB SDHC cards and BOTH have worked perfectly EVERY time including one which has been out, into a PC, out again and into a MAC, then back into the M20 and recorded our last nights gig both sets (45min + 1hr).
It's a little like the wireless dongles... Line6 give advice. If you choose not to follow that advice, don't blame the M20 if it doesn't always go smoothly.
  • 2
Complete DreamStage:
M20d with 2x L3m, 2x L3s, 2x L2t & 2x L2m
XD-V75HH & XD-V75BP wireless
#3 SiWatts69
SiWatts69
    Gear Head
  • PipPipPip
  • 506 posts
Posted 24 March 2014 - 04:04 AM
To follow up, used the same 32GB Samsung SD card this weekend after having deleted some files on the PC and everything recorded perfectly.
#4 jaminjimlp
jaminjimlp
    Gear Head
  • PipPipPip
  • 574 posts
  • LocationGeorgia
  • Registered Products:11
Posted 24 March 2014 - 06:45 AM
Wow that's great because usually when I would have a problem if I did not delete those files with the m20d, I have made three-hour in one shot recordings and had no problem but if I had deleted any files on a PC or Mac and then put it back and the m20d it would not work correctly.
As a sidenote four hours is the longest you can do one consecutive recording you could have several recordings at four hours on the 64-gig card and wouldn't have any problem.
May you be blessed and our Lord Jesus keep you!!!
#5 BucF16
BucF16
    Iknowathingortwo
  • PipPip
  • 263 posts
Posted 24 March 2014 - 09:38 AM
SiWatts, How 'bout citing where your "quote" comes from because my search couldn't find that in the manual.  Additionally I mentioned this in another thread and no one named Line6 responded that 32GB was the design limit.  The advanced guide's statement on SD card requirements is quite short, and mentions neither a maximum size of the card or SDXC or SDHC.
#6 tomtheguitarguy
tomtheguitarguy
  • 75 posts
  • LocationSoCal
  • Registered Products:6
Posted 24 March 2014 - 10:03 AM
BucF16,
No dog in this hunt, but from the M20d FAQ...
Q: Which SD cards are compatible with the StageScape M20d?
A: Any class 10 SD card will work with the StageScape M20d. Only class 10 SD cards are supported. SDXC cards are supported, as long as they are class 10. We do not recommend using SD cards larger than 32 gigs.
http://line6.com/sup...?st=0#comment_0
Hope this helps...
Tom
  • 1
www.TomTheGuitarGuy.com
www.TomcatsBand.com
G & L Will Ray Signature ASAT
Fender 52RI Telecaster w/ Hipshot B Bender
CIJ Fender 69RI Blue Floral Telecaster w/ McVay G Bender
Godin xTSA w/ Fishman Tripleplay
Quilter MicroPro 200-10 ~ Quilter Aviator Ultralight 8 ~ Quilter Steelaire ~ Quilter MicroPro 200 Mach 2 Head
Bose L1 Classic w/ 2 B1 Bass Bins ~ Bose L1 Compact
Line 6 JTV-69 James Tyler Variax
Line 6 PODHD500
Line 6 Stagesource L2t (x2)
Line 6 Stagesource L3t
#7 SiWatts69
SiWatts69
    Gear Head
  • PipPipPip
  • 506 posts
Posted 24 March 2014 - 10:14 AM
Sorry Buc...
Section 4.3 Multitrack Recording... "plug a Class 10 SD Card"
Section 4.7 Recording Times 32GB is largest quoted
There is then this...
http://line6.com/sup...ibility-an-r112
The following SD cards are compatible with the M20D:
•Any class 10 SD card is compatible with the M20D. Only class 10 SD cards formatted as FAT32 are compatible.
•32 GB maximum SD storage space
SDXC cards are (by default) formatted as exFAT so have to be reformatted to FAT32 and even then, may not be reliable. There's loads about SD cards all over the net.
As a 32GB card is plenty big enough for two full gigs for us, I don't see any benefit to trying to bend the specs to push a bigger card in. I did however buy an SDXC card first in error.
#8 BucF16
BucF16
    Iknowathingortwo
  • PipPip
  • 263 posts
Posted 24 March 2014 - 12:31 PM
Got it.  Honestly, the advanced guide has a very concise statement on compatibility that is clearly incomplete.
I purchases a Class 10 card that appears to be compliant with the Advanced guide but not with other online guidance.  Also had recording questions in a previous thread where none of these sources of information were brought up.
I guess now my question is, why in this digital online day and age, can't Line6 update the advanced guide and have it posted by sundown?  That would have saved me some time and money.  It's not like they print and send that thing out to you anyway, it's completely digital.
#9 BucF16
BucF16
    Iknowathingortwo
  • PipPip
  • 263 posts
Posted 30 April 2014 - 11:01 PM
Using my non-compliant Class 10 64gb card I was able to record an entire 4 hour gig no problem.
Prior to the gig I went through the trouble of actually erasing the disk, not just re-formatting, but writing zeros over the entire disk.  Took a while but worked like a champ after that.
Post gig, dropped them into Logic and had them cut into songs and mixed down within a couple hours.  Easiest I've ever seen.
Also tagged with one or more of these keywords: recording
