Model Pack Problem
keep in mind... you don't get metal shop presets....
look in the amp list for amps that start with MS, if you can access them it's working.
if the license manager shows the metal pack, and you've done the authorization... you should be all set.
Typically they will not refund an i-Lok purchase.
But you could call to see if they will work something out.
Other wise you can return the Metal Shop within 30 days and upgrade to POD Farm 2 Platinum, which has all the model packs.
Also, i-Lok is the plug-in only, where as the hardware independent version is stand alone and plug-in.
Alright, thank you for your help!
  • 8 months later...
