Output Setting
1 reply to this topic
#1 jhemo
jhemo
  • 1 posts
  • Registered Products:1
Posted 26 March 2014 - 02:18 AM
is it possible to use the unbalance and balance both output..how about in the global setup. is there any signal changes?'cause i want it to connect direct to mixing board and guitar amp together..
#2 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
  • Registered Products:5
Posted 26 March 2014 - 04:43 AM
Yes u can.
However output mode must be either "direct" or "combo/power amp". On the HD500 u cannot have different settings per output jack (1/4 - xlr's).
Proposed configuration with JTV+HD500 as follows:
Connect the JTV via VDI to the HD500 and use only the XLR’s out to the PA for ALL sounds (acoustic + electric) with “Studio direct” output mode.
Run the 1/4 out of the HD500 to  amp’s effects loop return, thus using the amp only as stage monitor.
In case u don't have a JTV, just connect thru the 1/4 guitar input.
