Can't Select Pod Farm In Garageband
garageband pod farm
4 replies to this topic
#1 imming
imming
  • 1 posts
  • Registered Products:1
Posted 30 March 2014 - 10:54 AM
I just upgraded to the latest version of Garageband (10.0.2) and installed POD Farm 2.57. For some reason I can't select the POD Farm Plugin any more. What am I missing here?
In a stand alone mode POD Farm is working fine.
Please assist.
Best regards,
Robert
#2 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7336 posts
  • Registered Products:6
Posted 31 March 2014 - 07:35 AM
Can you see it and not select it or cannot see it at all?
#3 robwall82
robwall82
  • 1 posts
Posted 26 May 2014 - 08:25 PM
Just downloaded the new version of garageband and Im having the same problem. I can use the stand alone just fine, but I can't find it anymore as a plugin in garageband. Help please?
#4 sjsmit0305
sjsmit0305
  • 1 posts
Posted 30 June 2014 - 09:53 AM
Upgrade your line 6 software to pod farm 2. When is Garageband create a new track selecting audio track or guitar track. In garage band double click in amp icon in track, under audio units, create plugin by selecting the line 6, then pod farm 2, then stereo drop down. This should pick up the signal in garage band through line 6 pod farm amp selection . . . worked like a charm 1st time. good luck!
#5 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17814 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 07 July 2014 - 07:32 AM
not 100% sure... but i do know that logic pro stopped supporting 32bit plugins... i suspect garageband is the same...
in which case you'd need to upgrade to pod farm 2.5+ for 64 bit plugins.
Also tagged with one or more of these keywords: garageband, pod farm
