imming Posted March 30, 2014 Share Posted March 30, 2014 Hi, I just upgraded to the latest version of Garageband (10.0.2) and installed POD Farm 2.57. For some reason I can't select the POD Farm Plugin any more. What am I missing here? In a stand alone mode POD Farm is working fine. Please assist. Best regards,Robert Quote Link to comment Share on other sites More sharing options...
Triryche Posted March 31, 2014 Share Posted March 31, 2014 Can you see it and not select it or cannot see it at all? Quote Link to comment Share on other sites More sharing options...
robwall82 Posted May 27, 2014 Share Posted May 27, 2014 Just downloaded the new version of garageband and Im having the same problem. I can use the stand alone just fine, but I can't find it anymore as a plugin in garageband. Help please? Quote Link to comment Share on other sites More sharing options...
sjsmit0305 Posted June 30, 2014 Share Posted June 30, 2014 Upgrade your line 6 software to pod farm 2. When is Garageband create a new track selecting audio track or guitar track. In garage band double click in amp icon in track, under audio units, create plugin by selecting the line 6, then pod farm 2, then stereo drop down. This should pick up the signal in garage band through line 6 pod farm amp selection . . . worked like a charm 1st time. good luck! Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted July 7, 2014 Share Posted July 7, 2014 not 100% sure... but i do know that logic pro stopped supporting 32bit plugins... i suspect garageband is the same... in which case you'd need to upgrade to pod farm 2.5+ for 64 bit plugins. Quote Link to comment Share on other sites More sharing options...
