V500, Reoccurring Issue W/ External Power
14 replies to this topic
#1 egkor
egkor
  • 78 posts
  • Registered Products:8
Posted 02 April 2014 - 06:57 AM
I have a 2005 Variax 500 that has an issue that has reappeared after having it fixed once in the past.
The issue is:  When connected to external power (described below) the sound/signal output of the Variax goes on and off (or cuts in and out), approx. 1.5 seconds "on" and .5 second "off", over and over.  Like this:  Sound, no sound, sound, no sound, etc.  Could be that the power input is cycling, thus causing the sound output to cycle on/off as well.  Not sure of root cause.
The V500 is connected to external power ("by the book") via connection as follows:
Original Line6 120VAC to 9VAC Power Supply (PN MW48T) --> Original Line6 Switch box --> Original Planet Waves TRS cable --> V500 Jack Plate
The 1/4 inch out of the Switch Box is connected to a guitar amp, powered on, and ready for play, the Switch Box footswitch is toggled to "1/4" (output to the 1/4" Jack then to the guitar amp), the Switch Box "Power" Light is "lit" confirming external power to the Switch Box.
Additional observations:
1)  With 6 AAs in the battery pack installed (and no external power), V500 output connected direct from its Jack Plate 1/4" to guitar amp 1/4" via regular (not TRS) cable, the Variax works normally.  Issue appears to be related to external power.
2)  For exactly the same issue, approx. 3 years ago, I took the Variax to a local Line6 recommended authorized service location. After diagnosing, Auth Service said the issue was with the Jack Plate.  After paying for parts and labor for them to replace the Jack Plate, the Variax worked for maybe another 2 years, now it has the same issue all over again.
3)  When the Jack Plate was replaced by Auth Service, the part they installed looks to be the same Jack Plate part as is used by more current Variax (rather than like the original with the "boot" cover).  The replacement Jack Plate is the newer version that has a trap door over the Ethernet port.(PN 50-04-0181-4 Full Compass).
4)  I recently obtained a JTV-69 Variax (on my way to the Dream Rig!) and verified the same original external power configuration works properly with the new Variax.
So here I am now, same issue as before.  I prefer to power the Variax via external power.  I can risk the approx. $30 US for the part, replace the Jack Plate myself, and hope that fixes the Variax (again).  I can't remove the Jack Plate from the JTV and try it on the V500 to see if that fixes it before I order a replacement because it appears the JTV Jack Plate is a different part # than for the V500.
I am surprised because I seem to be the only user this has happened/happens to.  Also with the revised Jack Plate installed at the first repair, I could not have thereafter accidentally shorted anything because the Ethernet port is covered by the trap door.
Is anyone familiar with this issue?  Any advice/wisdom WRT this issue?
Thank you,
-Gary K
Edited by egkor, 02 April 2014 - 07:24 AM.
Live Sound: Line 6: m20d, 2 x L3t, 2 x L2m
Variax:  JTV-69 (manuf. 3/2012), Variax 500 (manuf. ~2003)
Guitar Amps:  DT50 Head, DT25 Head, 2-Marshall 1936 2x12 cab (2xCelestion G12T-75)
Modellers:  POD HD500
Other:   Fender Strat HSS, MIM (~2012), Taylor 614ce (2011), Taylor 315ce (2010)
#2 arislaf
arislaf
    Power User
  • PipPipPipPip
  • 1818 posts
  • LocationGreece
  • Registered Products:12
Posted 02 April 2014 - 08:45 AM
It is strange that with the jtv is working good... Stupid question, but did you had the battery in the jtv when you tried it?
Before line6 was called line6... they used to do r&d for other companies like alesis + others. and when those customers came to visit the offices of line6 (before it was called line6) and the receptionist needed to warn all the guys who were designing products for other companies (and for themselves... ) who were like 'in the back' the receptionist would announce over a tannoy 'tellephone call for 'fred smith' on line 6' the cunning part was that they only had 5 telephone lines, so it was the secret code for "hide your sh1t the feds are comin'" or "someone's coming, let's hide these PODs that we aren't going to release for another few years so they don't see them"
BEST CABS: www.studiocat.com
#3 egkor
egkor
  • 78 posts
Posted 02 April 2014 - 09:55 AM
Hi, what I'm pointing out is, the issue is not with the external power chain itself since it successfully powers the JTV.  It is pointing at something about the Variax 500 not working with known good external power, but working with battery power.
Now if you are asking if I tried the V500 with external power connected, and AA battery pack installed, no I have not tried that yet.
But what I want is for the V500 to work solely when connected to external power.
Thanks!
-Gary K
#4 arislaf
arislaf
    Power User
  • PipPipPipPip
  • 1818 posts
  • LocationGreece
Posted 02 April 2014 - 12:45 PM
No, what I mean is the battery from the jtv if it was removed. In case it was removed, and the jtv is working properly, it could be a problem from your variax 500, could be a cable short circuiting from inside the guitar body. That would explain the power cut off-work when on electricity, and the reason the guitar is working properly with the batteries.
Just my 1 cent of though...
#5 egkor
egkor
  • 78 posts
Posted 02 April 2014 - 12:52 PM
Ahh ...  I see!
No, the battery was not in the JTV when I powered it via the external power supply.
Thanks again,
-Gary K
#6 arislaf
arislaf
    Power User
  • PipPipPipPip
  • 1818 posts
  • LocationGreece
Posted 02 April 2014 - 01:03 PM
Welcome Gary  :) If you have an authorized center in your area, I would strongly suggest you to sent your guitar there and explain them the problem. Or you can check by yourself by opening your guitar and see if the cables are ok near the 1/4 cable input of your guitar. (sometimes even the soldered metal goes off)
#7 amx05462
amx05462
    Guru
  • PipPipPipPipPip
  • 3516 posts
Posted 05 April 2014 - 09:28 AM
 in past   if  some users   left the batteries  in there older  variax when using  external  power  the  main board  would  cycle  bac  and  fourth  to both  power  supplies.  removing the batteries   solved  this  problem  for  some . others  found  that there  was  a resistor problem  on the main board.
#8 egkor
egkor
  • 78 posts
Posted 08 April 2014 - 09:27 AM
Thanks for your input!
Update:  Since the issue was solved once in the past by replacing the Jack assembly, I'm going to try that.  I have a replacement Jack assembly on order from Fullcompass, I will change this out and repost with results.
-Gary K
#9 jlamarmiller
jlamarmiller
  • 9 posts
Posted 16 May 2014 - 08:30 PM
I am having the same issue. I believe mine to be a shorted wire, as I can "jiggle" the wires and sometimes it starts working.
#10 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 18 May 2014 - 08:11 AM
Does it work with batteries?  If so, there is very little to troubleshoot since it picks up power on the TRS connector.
#11 DarrellM5
DarrellM5
    Gear Head
  • PipPipPip
  • 929 posts
  • LocationRound Mountain, NV
  • Registered Products:5
Posted 18 May 2014 - 01:06 PM
Just curious; which part number are you ordering from fullcompass?
#12 egkor
egkor
  • 78 posts
Posted 02 July 2014 - 09:36 PM
@DarrellM5,
Here is a link to the FC page w/ the part I ordered for my V500:
http://www.fullcompa...uct/431850.html
I have received the part but have not installed it as of this date/time.
-Gary K
#13 DarrellM5
DarrellM5
    Gear Head
  • PipPipPip
  • 929 posts
Posted 03 July 2014 - 05:10 AM
Thanks Gary, please let me know if it fits.  I need to replace the jack in my 500 as well.  The connections has gotten loose for the VDI cable over time.  I was leary to order that part as it doesn't specifically say that it fits the 500.
#14 studiok
studiok
  • 3 posts
Posted 04 October 2014 - 11:48 AM
I've had the problem and it's a simple fix...there is a 47mF, 16v capacitor soldered to your jack plate...either one leg is not making contact ( my neg terminal ) or the cap needs replacing...mere pennies not $24 for another jackplate...remove screws and cover plate from the back of the ax and unplug the main connector to the board,( no heat buildup transferred to the main board ), unscrew and pull jackplate out of guitar and resolder or replace cap...reattach wire harness to main board and test with external power pedal
#15 jlamarmiller
jlamarmiller
  • 9 posts
Posted 28 October 2014 - 06:01 AM
I was able to fix mine by resoldering some wires.
