Sv Hd100 Help ... I Got Nothing!
10 replies to this topic
#1 atreyu2112
atreyu2112
  • 29 posts
  • Registered Products:2
Posted 27 May 2013 - 04:23 PM
Hi guys. I have the first version head.
When I power it on, the screen is half black and half blank. The board reads "FBV SB MKII". No sound, no presets. It is staying this way.
No power surge, nothing through the loop & tubes look to be OK (they are old tho), all are lit and seated properly. Amp was sounding fine and I have never had an issue with it before. I bought it new (original owner) and I treat it well.
I don't know what to do and none of the techs around here are really familiar with hybrid amps.
Is it simply a bad power tube or am I in trouble? HELP. Thanks in advance.
#2 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
  • Registered Products:1
Posted 28 May 2013 - 05:54 AM
Factory Reset
You can reset your Spider Valve’s programmable channels to their factory-programmed
states by holding down the Channel A button as you turn on the power. erases your stuff
I'M SO HAPPY!
#3 atreyu2112
atreyu2112
  • 29 posts
Posted 28 May 2013 - 10:18 AM
I called them. They were very helpful. The tech did mention the reset too, but my issue turned out to be a faulty ethernet cable for the Short Board. Whew . . . I was getting real nervous. Thanks toneman & Line 6
  • 1
#4 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 28 May 2013 - 10:26 AM
excellent
  • 1
I'M SO HAPPY!
#5 napynap
napynap
    Iknowathingortwo
  • PipPip
  • 286 posts
  • LocationPalmdale, CA
  • Registered Products:4
Posted 28 May 2013 - 09:09 PM
One time my SV212 mk2 stopped responding on stage, and it was resolved by reseating the ethernet cable at the footpedal. The fix for that type of issue is hard to recognize as it doesn't seem to be related to a data connection like this.
#6 atreyu2112
atreyu2112
  • 29 posts
Posted 30 May 2013 - 05:54 PM
Well, it was not the ethernet cable as the amp started acting up again today... no sound, volume - just black bars on the screen. UG...
#7 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 30 May 2013 - 06:50 PM
did you try the reset?
I'M SO HAPPY!
#8 atreyu2112
atreyu2112
  • 29 posts
Posted 31 May 2013 - 04:56 AM
Yes, it's not even letting me do that. Right on power up... 8 black bars and a blank screen.
#9 esibanjack
esibanjack
  • 50 posts
Posted 31 May 2013 - 10:32 AM
From reading the old message board it appears that this issue is a symptom of a problem with the digital side of the amp (it was often referred to as “The Black Bars of Death”). If the reset doesn’t work (or isn’t possible) the only other option is to bring it in for service.
#10 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 31 May 2013 - 11:16 AM
it's strange how this worked for you then the problem returned. i'm guessing you repeated the steps you took to get it working.
give it a good rap with you hand when you turn it on
I'M SO HAPPY!
#11 atreyu2112
atreyu2112
  • 29 posts
Posted 31 May 2013 - 06:17 PM
Yeah, it's gotta be serviced. I'm very sad. I'm gonna be without the amp for a few. I hope it's something simple.
  • 1
