Increase In String Breakage Compared To Other Guitars?
14 replies to this topic
#1 clay-man
clay-man
    Power User
  • PipPipPipPip
  • 1964 posts
  • Registered Products:3
Posted 27 May 2013 - 06:35 PM
Anyone notice any increase in string breakage with their Variax? I've noticed that I break a string within a month of play on my Variax. On my Davison Tune O Matic SG, my strings virtually lasted forever.
I used GHS 11's on the Variax. I recently switched to Ernie Ball Power 11's to see if it'll help.
Do you think the piezos are choking out my strings on the bridge? It seems like a slightly sharp angle where the string bends over the piezos, so it might be cutting it in half over time.
Does anyone have better string life with the graphtech ghosts?
For a minute there, I lost myself.
#2 orangekeeper2
orangekeeper2
  • 80 posts
  • Registered Products:5
Posted 28 May 2013 - 03:55 AM
I use Graphtech ghosts with a Floyd Rose on my tranplants and usually have to change strings once every few months, but only due to string wear, not from breaking at the bridge... The graphtechs apparently have some kind of coating on the saddles to reduce string wear...
I don't remember my 300 bridge ever having problems with this though...
This guy suggests a shim if the angle of the string isn't correct... Although the OP's fault is different from yours, the same fix may help you? http://line6.com/sup...-my-variax-500/
#3 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 28 May 2013 - 04:56 AM
I'm still using the D'Addario 10's on my stock JTV59 and I've had no string breakage problems.
#4 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
  • Registered Products:1
Posted 28 May 2013 - 04:59 AM
http://line6.com/sup...?view=documents
I'M SO HAPPY!
#5 clay-man
clay-man
    Power User
  • PipPipPipPip
  • 1964 posts
Posted 28 May 2013 - 05:22 AM
 JTV's piezos are a lot more rounded than the V1 Variaxes so it probably reduces string breakage. V1 Variax piezos protrude from the saddle a little bit, and might have a little bit of a choke angle.
link doesn't work
  • 1
#6 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 28 May 2013 - 05:42 AM
link doesn't work
crap, screwed it up. just google guitar string breakage. bunch of reading and fixes. although your last post seems fitting
I'M SO HAPPY!
#7 Mr_Arkadin
Mr_Arkadin
    Guru
  • PipPipPipPipPip
  • 2817 posts
  • Registered Products:6
Posted 29 May 2013 - 06:44 AM
Lowly 300 here and no such problems. I use 11s.
#8 Sonny1096
Sonny1096
  • 41 posts
Posted 29 May 2013 - 07:17 PM
JTV-69 with 10s here, haven't noticed any more breakage than other Strats.
#9 davidb7170
davidb7170
    Gear Head
  • PipPipPip
  • 841 posts
  • LocationDavenport, IA
  • Registered Products:9
Posted 03 June 2013 - 07:44 PM
I started out in Variax-land with a 300 and now have 2 JTV's, a 59 & a 69S, but I did have some issues with the 300. I always used 0.009's on my strat with occasional breakage towards the end of the strings useful life, but with my 300 set up with 0.009's, I would get only a couple of shows played, and would have a string break -- usually the B string, if I recall right... Don't know if it was saddle related. ANYWAY, I changed to 10's and the problem stopped. I had to get used to the slightly heavier gauge, but now that's all I use. I do hand vibrato and note stretches like everyone does, and (knock wood) haven't popped a string on my 59 or 69S. I don't really use the whammy on my 69S or on my strat, so don't get much breakage related to that.  Now using 10's is just out of habit. My strings start going dead on me before I break any, and I change them more for that reason. 11's seem a bit stiff to me, but it's usually the lightest string you can get for acoustics, so my hands take more of a beating when I play my acoustics or my acoustic/electric... My acoustic 12-string really makes my fingers sting if I play it for any length of time....
Dave
Line 6 Gear - Variax 300; JTV-59, JTV-69S, Pocket-POD, POD XTL - (RIP), POD X3L, HD500, HD500X, HELIX
1966 Gretsch Country Gent, 1973 Fender Tele Deluxe, 1978 Strat, 2017 Tele Elite, Epiphone LP Classic, Epiphone Special with P-90's
Gigging Amps: Alto TS210, Alto TS112A, Quilter Tone Block 200, Crown XL1000; Yorkville NX35 Speakers
#10 clay-man
clay-man
    Power User
  • PipPipPipPip
  • 1964 posts
Posted 03 June 2013 - 08:21 PM
Dave
Thanks Dave. I have a feeling the Variax chokes the strings a slightly more than on other guitars. It might be my piezos being old or something, but it does have a bit of an edge on the saddles and piezo, which is where I think it's choking the strings, so you basically might have a sharp angle that the string bends and sits on, both maybe weakining the string a bit and breaking it more than normal saddles.
I did lower the action a bit because I think the saddles were angled a bit up so that might be doing some choking too, but I don't want it too low or else it'll start buzzing out on the frets.
#11 Spiderplayer7
Spiderplayer7
  • 59 posts
  • LocationManchester, UK
Posted 06 June 2013 - 04:02 AM
I've used my 700 trem for some years now and never once broken a string. I use Ernie Ball Regular Slinkys (they're 10s).
#12 Fisack
Fisack
  • 1 posts
  • Registered Products:4
Posted 01 July 2013 - 08:23 AM
I have had my 500 for 10 years now, and I experience breakage on my LOWER strings- usually E or A. It's quite annoying, and I have taken to buying individual A strings since they need to be replaced more often.
I think the problem is in the angle of the string coming over the pickup. I have tried sanding down the string guide, but that doesn't seem to work. As it is, I just regularly replace the strings every three months so that I won't be onstage with a broken string. (I play about two hours a week with our church band, so your playing tone should vary.)
#13 cz-milan
cz-milan
  • 18 posts
Posted 28 July 2014 - 08:33 AM
I put a little bit of silicone foil between string and saddle. No influence to sound - no string breakage after that fixing.
Milan
#14 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 28 July 2014 - 09:46 AM
Never had string breakage problems with my 500.  They wear out before they break.  Never broken one on my JTV69S either.
#15 clay-man
clay-man
    Power User
  • PipPipPipPip
  • 1964 posts
Posted 29 July 2014 - 02:51 AM
Keep in mind that this topic is old. I've since fixed the problem. I did have a string break on my E but that's because I kept detuning it as well as stretching it hard, so that's to be expected.
The action was too high and it choked the strings making them break overtime.
Using Elixir 10's polyweb.
