Hd500 Effects Pre Vs Post Amp (w/ No Amp Assigned)
hd 500 hd 500 as effects effects pre post amp block
7 replies to this topic
#1 berkleegrad
berkleegrad
  • 38 posts
  • LocationOrlando
  • Registered Products:2
Posted 05 April 2014 - 11:04 AM
 Greetings all,
apologies, since I'm sure this topic has been covered before (maybe years back in the old forums)...
I use my HD 500 both as stand alone unit for FOH and/or as a straight up effects in front of an old Bassman rig....
When mashing up some new patches for use with my AMP I noticed that the sound of a my tube drive before the an empty amp block sounds completely different
Attached File  preamp.JPG   29.1KB   15 downloads
than post empty amp block.
Attached File  postamp.JPG   26.81KB   3 downloads
I would expect this behavoir when there is an actual Amp assigned - I don't know why it surprised me that it is occuring when there is no amp in the amp block. I guess I was expecting just a transparent passing of the sound.  =:o
thanks in advance for your input, -Rick
appreciate your indulgence, -Rick
Rick Richbourg
http://rickrichbourg.com/
http://www.facebook.com/rickrichbourg
http://groovetherapy.us/
#2 radatats
radatats
    Power User
  • PipPipPipPip
  • 2322 posts
  • LocationOrange County, NY
  • Registered Products:3
Posted 05 April 2014 - 01:18 PM
how do you have your inputs set?  are you using input 2 as Same or something different from input 1?  that will change the signal strength hitting the TD before the amp vs after the amp...
  • 1
#3 berkleegrad
berkleegrad
  • 38 posts
  • LocationOrlando
Posted 05 April 2014 - 07:36 PM
Radatats, thanks for taking the time to reply.
Input 2 is set to Variax which I'm NOT using. In the mixer, both input faders are centered and at 0dB.
The Tube Drive before the empty amp blocks sounds crisp and defined tonally; but when I place it (without changing any of the device parameters) behind the empty amp block, the Tube Drive sounds dull and lifeless. Been using the HD 500 for 3+ years - in a variety of ways and this is the first time I've every tried any effects behind an empty effects block. And, never noticed (or paid attention) any difference behind an assigned amp block. :-)
Again, thanks for your reply, -Rick
Rick Richbourg
#4 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
  • Registered Products:5
Posted 07 April 2014 - 02:06 AM
1st picture: tube drive applied over BOTH paths
2nd picture: tube drive applied ONLY over path A, path B carries pure guitar signal.
c attached abstract from "POD HD500 Advanced Guide v2.10 - English ( Rev A )", page 6-2.
"With the Amp in Pre, as shown above, the single amp feeds both Paths A & B."
Attached File  amp-mono.png   39.94KB   2 downloads
  • 2
#5 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
Posted 08 April 2014 - 01:27 AM
nico, after each "null" amp block the signal sums up 2 mono.
so, in pictue 2 abv, regardless if input2=zero, path b is still fed with unprocessed guitar signal.
however, things would be different if the amp block was placed after the mixer (c attached pic).
#6 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
Posted 08 April 2014 - 02:39 AM
ok nico, trial (...'n error) is always the best way to find out anything u are searching 4.
can u pls also try the config of the pic I attached (amp after mixer) to verify any differences?
#7 berkleegrad
berkleegrad
  • 38 posts
  • LocationOrlando
Posted 08 April 2014 - 03:16 AM
Nico,
awesome thank you very much! Here is another +1 on pinning your post > How Has Greatly Improved My Use Of The Hd500  lots of helpful info on the 'single input approach'.
As a HD300 owner also - I have indeed noticed how much easier it was to arrive at a great sound - [not necessarily related to this topic - I also really like the flexibilty of being able to send easily send a full cab feed to FOH and another without the cab to my rig. (yes I played for a long time with a FRFR wedge; but, really missed the whole guitar into the amp sound on stage)]
Of course as luck would have it, I did come across your thread after I had posted my original question and probablly would have posted anyway since my question was also not just about the placement of the tube drive; but, that there was NO amp in the block and it was as much an observation as anything else.
When I was reading your post, I was remembering the epic thread from 2011 > What every HD500 owner needs to know and it's spawn > What every POD HD 500 owner *REALLY* needs to know.    < I am including those references for those who may come later with similar questions - AND as a reminder that many good peeps have been to solve the many secrets of the HD500 and SHARE results about these issues for a long time! thank you for being such a significant contributor. ;)
(sorry for any typos - my firefox spell check doesn't seem to work in this input box)
Rick Richbourg
#8 berkleegrad
berkleegrad
  • 38 posts
  • LocationOrlando
Posted 08 April 2014 - 03:23 AM
Jandrio,
appreciate your contibution to the conversation - and there is alway good council in the 'suggestion' to RTFM (your first post) -  reading the freekin manual is an often overlooked source of info which I am often guilty.
I will later also try and confirm or deny that a blank amp block sums to mono - though Nico has a lot of trial and error invested in sharing his info and as I grow lazier i tend to defer to other's experience =:o
again, thank you for your input.
  • 1
Rick Richbourg
Also tagged with one or more of these keywords: hd 500, hd 500 as effects, effects pre post amp block
