Porting Of The .h5e Files Into Podfarm
.h5e pod farm
2 replies to this topic
#1 kylegonyer
kylegonyer
  • 21 posts
  • Registered Products:2
Posted 05 April 2014 - 05:10 PM
There are some pretty sweet tones out there uploaded by HD500 users and you can use these and or tweak/convert them in farm if you download POD HD500X Edit
As a tip you can open farm and 500edit at the same time and mimic (as best you can), the FX and the ordering of them + settings.
In 500, all the settings will be in front of you in the interface see below ....so that makes it easy.
Next you need to manually adding them in farm as best you can. There was one FX in this example HD500 tone that literary does not exist in Farm. It was this "colordrive distortion" pedal.
Had to google it, as I never heard of this pedal before....so learned something new I guess.
Anyway, you may have to find a substitution in these cases.
See next image below which is the same tone now in farm (at least a best effort).
If you can match and get the ordering close, this technique may work well for you to get some additional tone by users when you don't own the HD500.
  • 1
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16060 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 05 April 2014 - 06:22 PM
That's a good strategy to get a starting point. Users need to be aware, though, that they should not expect to hear identical tones even with the exact same amps and FX selected, with the exact same parameter settings for each amp/FX. That's because the underlying modeling (DSP software) is completely different. So use this technique as a starting point for further tweaking to get a tone that sounds good to you.
.... John Lennon
#3 kylegonyer
kylegonyer
  • 21 posts
Posted 06 April 2014 - 03:53 PM
good point, I am not an expert at the HD500, so yea it makes sense it would have different algorithms or DSP software. Yes, I am using for just a good start and see what others are doing for say a Van Halen tone or so.
Also tagged with one or more of these keywords: .h5e, pod farm
