mgr10 Posted April 9, 2014 Share Posted April 9, 2014 Hi Sorry for my english Prague - Czech republic :)I want to share the experience with sound settings, specifically Podem HD 500 and DT 25thAfter a few hours of laboring 1.SETTING sound DT25 without Pod HD 500 - DTEDITfimware version 2.0I figured out that the sound is set in Dt25/50 are complete simulation preamp and poweramp and cabinet ! !.Line6 calculated about the fact that they will use Line6 speaker cabinet compatible with Dt 25 /50.Sound comes out of the cabinet as a whole . eg JCM 800 - GT75 .If you use a different head with a box , so you must turn off the DT -Edit cab simulation ! !2. POD HD 500 -DT 25/50 and Line6 speaker cabinet .Use eg HD -edit or set directly on Pod HDPod HD connected with DT 25/50 - L6 LINKBelow I have set the output to Stack power amp.In HD edit a selection of amplifiers complete preamp poweramp and cab.You can also just preamp with a cab or without. 3.POD HD -DT 25/50 and other speaker cabinets Pod HD connected with DT 25/50 - L6 LINKset the output to Stack power amp.Selected only preamp and a cab. Simul off !!More knowledge.If you are using REVERB in Pod HD , you need to off - reverb DT 25/50 to zero.Sorry for my English Quote Link to comment Share on other sites More sharing options...
Brazzy Posted April 9, 2014 Share Posted April 9, 2014 Nice info. Just want to give you a heads up. You should update your Pod HD500 with the new firmware that was just released. Thread Link Quote Link to comment Share on other sites More sharing options...
