andrewlf Posted April 10, 2014 Share Posted April 10, 2014 Hi I am unable to connect to custom tone from within line6 edit. When I try to do this I get a java error and the software has to be closed. Java Platform SE binary has stopped working I've uninstalled all versions of Java and reinstalled Line6 edit and let it install a version of Java but the problem persists . Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 10, 2014 Share Posted April 10, 2014 First off, what device are you trying to use? Quote Link to comment Share on other sites More sharing options...
papajoetucker Posted September 12, 2014 Share Posted September 12, 2014 I am having this same issue. I've uninstalled all versions of Java and reinstalled Line6 edit and let it install a version of Java but the problem persists. Still get the Javaâ„¢ Platform SE binary has stopped working. My device is a PODxt. And my laptop is Windows 7 64 bit. I also use Mozilla FireFox but the Internet Explorer opens to a blank page when I click continue. Please help if you can. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted September 12, 2014 Share Posted September 12, 2014 gearbox replaced line6 edit long ago... its possible that the links etc embedded in the edit program are simply broken, and its not a java or edit issue really.. just an issue of the software being past it's prime... Quote Link to comment Share on other sites More sharing options...
papajoetucker Posted September 12, 2014 Share Posted September 12, 2014 And so you are saying that I am at a dead end street because I using a older PODxt? What is my recourse? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted September 12, 2014 Share Posted September 12, 2014 No i'm saying that there is newer software available that you can use to edit your XT, it's called gearbox. go here and you should see it: http://line6.com/software/ should also show available in line6 monkey if you have that installed... and also.... you can download tones directly from here: http://line6.com/customtone/ outside of edit. Quote Link to comment Share on other sites More sharing options...
Maxblender Posted October 4, 2014 Share Posted October 4, 2014 I have the same problem, I'm running windows 8.1 64. I tried to install the latest versions of the softwares but I stll get the error message about java. I don't know what to do anymore. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted October 5, 2014 Share Posted October 5, 2014 the newer software GEARBOX does not require java... but much depends on what device you are trying to use.... I have the same problem, I'm running windows 8.1 64. I tried to install the latest versions of the softwares but I stll get the error message about java. I don't know what to do anymore. Quote Link to comment Share on other sites More sharing options...
Maxblender Posted October 5, 2014 Share Posted October 5, 2014 my bad I should have given some precisions, I'm trying to use a POD XT LIVE Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted October 5, 2014 Share Posted October 5, 2014 then you can certainly use gearbox, which will not require java my bad I should have given some precisions, I'm trying to use a POD XT LIVE Quote Link to comment Share on other sites More sharing options...
Maxblender Posted October 5, 2014 Share Posted October 5, 2014 thanks, I'll try that Quote Link to comment Share on other sites More sharing options...
