Recording Playback Device Pod Xt
7 replies to this topic
#1 Punkyboy
Punkyboy
    Iknowathingortwo
  • PipPip
  • 262 posts
  • Registered Products:2
Posted 11 April 2014 - 07:33 AM
Hello
When I set de playback and recording device to the Pod xt and I plug a headseat everything is ok
I can hear the song played with a player and my guitar.
But when I want to recording the both it doesn't work ??
It record only the guitar and not the song
What I want to do is playing with the song and recording both!!
I try also with the player of the pod , but no way
Is it possible ???
Windows 8.1
No external speakers !!
TX ;)
Line 6 Pod Hd 500X - Gibson The Paul II -  LTD Viper -  J&D Stratocaster Vintage - Line 6 Variax Standard
 Boss DR 670 - Line  6 EX 1 - Pigtronix Infinity looper - BeatBuddy
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15290 posts
  • LocationOntario, Canada
  • Registered Products:15
Posted 11 April 2014 - 07:52 AM
You can't record the incoming backing tracks/song unless you connect them to the Pod's processing inputs. The Pod only sends its own sounds to your computer for recording. It does not send its incoming usb stream nor the input from its cd/mp3 player.
.... John Lennon
#3 Punkyboy
Punkyboy
    Iknowathingortwo
  • PipPip
  • 262 posts
Posted 11 April 2014 - 07:58 AM
ok Thank you !
#4 BillBee
BillBee
    Power User
  • PipPipPipPip
  • 2183 posts
  • LocationMichigan
  • Registered Products:8
Posted 11 April 2014 - 07:59 AM
You might be able to run a 'Y' cable from the XT's headphone jack (1 male, 2 female). Use one for the headphones the other for running a line in to your sound card. You will have to figure out the level volumes on your DAW. You could probably just solder the cables together yourself to save a few $.
-B
Smell the glove.
#5 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 6869 posts
  • Registered Products:6
Posted 11 April 2014 - 08:48 AM
How are you playing the song? PC? MP3 player, I-Pod?
A typical work flow is to import your song into your DAW.
Then play along with it while you record.
This also give you more control when mixing.
#6 Punkyboy
Punkyboy
    Iknowathingortwo
  • PipPip
  • 262 posts
Posted 11 April 2014 - 10:42 AM
yaeh I playing the sound from the computer and play with it
ANd want to record both
but was to try with the Pod alone to do this !!
I was trying to use the pod for play and record at the same time !
#7 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 6869 posts
Posted 11 April 2014 - 11:49 AM
SO what source id the sound on you computer?
If it is from your music library just import it into your DAW onto its own stereo track.
#8 Punkyboy
Punkyboy
    Iknowathingortwo
  • PipPip
  • 262 posts
Posted 11 April 2014 - 11:34 PM
Yes it's from a library
tx
