Punkyboy Posted April 11, 2014 Share Posted April 11, 2014 Hello When I set de playback and recording device to the Pod xt and I plug a headseat everything is ok I can hear the song played with a player and my guitar. But when I want to recording the both it doesn't work ?? It record only the guitar and not the song What I want to do is playing with the song and recording both!! I try also with the player of the pod , but no way Is it possible ??? Windows 8.1 No external speakers !! TX ;) Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 11, 2014 Share Posted April 11, 2014 You can't record the incoming backing tracks/song unless you connect them to the Pod's processing inputs. The Pod only sends its own sounds to your computer for recording. It does not send its incoming usb stream nor the input from its cd/mp3 player. Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted April 11, 2014 Author Share Posted April 11, 2014 ok Thank you ! Quote Link to comment Share on other sites More sharing options...
BillBee Posted April 11, 2014 Share Posted April 11, 2014 You might be able to run a 'Y' cable from the XT's headphone jack (1 male, 2 female). Use one for the headphones the other for running a line in to your sound card. You will have to figure out the level volumes on your DAW. You could probably just solder the cables together yourself to save a few $. -B Quote Link to comment Share on other sites More sharing options...
Triryche Posted April 11, 2014 Share Posted April 11, 2014 How are you playing the song? PC? MP3 player, I-Pod? A typical work flow is to import your song into your DAW. Then play along with it while you record. This also give you more control when mixing. Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted April 11, 2014 Author Share Posted April 11, 2014 yaeh I playing the sound from the computer and play with it ANd want to record both but was to try with the Pod alone to do this !! I was trying to use the pod for play and record at the same time ! Quote Link to comment Share on other sites More sharing options...
Triryche Posted April 11, 2014 Share Posted April 11, 2014 SO what source id the sound on you computer? If it is from your music library just import it into your DAW onto its own stereo track. Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted April 12, 2014 Author Share Posted April 12, 2014 Yes it's from a library tx Quote Link to comment Share on other sites More sharing options...
