Undo Changes In X3 Patches
6 replies to this topic
#1 PeteParisetti
PeteParisetti
  • 4 posts
Posted 13 April 2014 - 12:58 PM
Hello forum.
I must be thik. I don't understand - and I cannot find on the manual - how to undo changes that intervene in my X3 live patches. As I play live, some of the controls move unintentionally and the patch gets modified. I simply want to get back to the orinigal patch I saved.
Thanks for any wisdom.
Pete
http://bluepete.wix.com/pete
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16057 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 13 April 2014 - 01:14 PM
Just reselect the patch using the foot switch. You may have to select a different patch first, then back to the original.
To prevent this from happening, try 'parking' the silver knobs by moving them to the end position, right or left.
.... John Lennon
#3 PeteParisetti
PeteParisetti
  • 4 posts
Posted 13 April 2014 - 10:48 PM
mmm... thanks for the tip, but it doesn't seem to work that way... the asterisk indicating that the patch has been modified wont'g go away, hence i reckon the mods stay even cycling through different patches - that's why I am confused.
#4 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16057 posts
Posted 14 April 2014 - 04:19 AM
Are you running Gearbox while doing this? If so, use the GET command to restore the preset.
.... John Lennon
#5 PeteParisetti
PeteParisetti
  • 4 posts
Posted 14 April 2014 - 05:22 AM
no, negative. just the pedal on its own. the asterisk will remain, no matter what I do, except to re-save the patch (whcih I don't want to do)
#6 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16057 posts
Posted 14 April 2014 - 05:33 AM
Maybe the asterisk remains even though the patch has, in fact, been restored? Test this by making a really obvious-sounding change to the patch then try to restore it using footswitches to change to a different patch then back again. Might also be worth firing up Gearbox to see if the GET command restores it.
.... John Lennon
#7 PeteParisetti
PeteParisetti
  • 4 posts
Posted 14 April 2014 - 10:25 AM
OK, thanks anyway. I really appreciate you taking the time and sharing your suggestions.
