criminalpan Posted April 14, 2014 Share Posted April 14, 2014 Am I able to use a cable splitter to run left and right outputs from my pod hd desktop into one channel of my tascam us-1800? Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted April 14, 2014 Share Posted April 14, 2014 If you use one cable you get mono anyway. Use one of the 1/4 inch outputs and you get both left and right combined. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted April 14, 2014 Share Posted April 14, 2014 you'll need to use 2 channels, in from the us1800, but you can select them as a single stereo channel in your DAW/ what i do (i have the same interface) is go in with the SPDIF, which i've set to dry in the setup menu, and also go into the rear 11/12 or 13/14 inputs on the us1800 you can of course just go with a single SPDIF cable wet and be done with it..... this is just so that i can record both wet and dry... you may not have the desire, just gives me options post recording... besides re-performing. Quote Link to comment Share on other sites More sharing options...
criminalpan Posted April 14, 2014 Author Share Posted April 14, 2014 Sow SPDIF on the pod to Digital in on the tascam would suffice ? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted April 14, 2014 Share Posted April 14, 2014 Yeah, works great... just go through the SPDIF menu in the pod and set your sample rate or accept the defaults.... should work either way. Sow SPDIF on the pod to Digital in on the tascam would suffice ? Quote Link to comment Share on other sites More sharing options...
criminalpan Posted April 14, 2014 Author Share Posted April 14, 2014 Very cool much thanks Quote Link to comment Share on other sites More sharing options...
