Pod X3 Bean (not Live/pro) And Midi/usb
x3 midi m-audio uno mac
13 replies to this topic
#1 luizmessora
luizmessora
  • 4 posts
  • Registered Products:1
Posted 29 May 2013 - 07:24 AM
Hey everyone. I got a POD X3 bean and a M-Audio UNO MIDI-USB interface and i'd like to connect them to my computer (which is a Mac). However, as far as I'm concerned, the X3 bean does not have a MIDI output/input (which is kind of odd since the lower-end POD 2.0 does) and I'm trouble here..
What I want to do is very simple: just use my headphones to listen to what i'm playing in my guitar through the POD and to music playing from my computer at the same time. If I connect my headphone to the headphone jack in my POD and connect the POD to my Mac directly via USB, I can use the POD as my soundcard, right? So any sounds coming from the computer would be played through the POD to my headphones in the same way my guitar playing would, right? Most of the time I'm just playing along songs I have here, and if i can just play something on iTunes and hear it on the same headphone I'm using with my POD that would be great, it would solve most of my problems. With this can I also record stuff (simple stuff, just using GarageBand or whatever...)?
And I'd also like to know if there is any way around this MIDI problem with the X3.. I figured the MIDI would be a good way to control the POD via computer. Using direct USB connection, I cannot control the pod using the computer, right? Bummer... Is there anything I can do to this?
Thanks!
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 8486 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 29 May 2013 - 07:43 AM
You're correct on the fact that the POD does become your soundcard when connected with USB. As far MIDI, the X3 bean has no MIDI capabilities whatsoever. It doesn't have MIDI ports, and it doesn't do MIDI over USB. So on that end there's not really anything you can do.
  • 1
#3 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17728 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 29 May 2013 - 09:33 AM
you CAN control it using usb... install gearbox...
  • 1
#4 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 8486 posts
Posted 29 May 2013 - 10:09 AM
Well, true... I was assuming he was meaning controlling it via MIDI PC and/or CC commands sent from a DAW.
#5 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17728 posts
Posted 29 May 2013 - 10:59 AM
I guess i just had a different perspective of the question... you may well be correct.
#6 luizmessora
luizmessora
  • 4 posts
Posted 29 May 2013 - 12:41 PM
Thank you both very much. I was actually assuming using MIDI was the best way to control the POD, but if I can simply use USB and use POD as a soundcard that way, what would MIDI do for me? I'm not sure i understand what is the purpose of MIDI anyway.
Via USB I can also use GarageBand or any other software to record eventually, right? I don't have a USB cable right now but i'll buy one and post here later when I can.
Thanks
#7 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 8486 posts
Posted 29 May 2013 - 01:30 PM
Well, if by controlling the POD, you just mean editing and arranging presets, Zap is correct - Gearbox allows you to do that over the USB connection. As far as having MIDI and using the computer, there are some people who like to set up automation tracks in their DAW to control the POD so that the DAW turns effects on and off or changes patches, etc. during the course of a song. If you don't know what the term "automation track" means, then that probably doesn't apply to you. Other than that, MIDI gives you the ability to control the POD with third party controllers.
  • 1
#8 luizmessora
luizmessora
  • 4 posts
Posted 29 May 2013 - 09:31 PM
hmm, thanks. that would be nice to have by I'm good so far with just the USB! in any case the x3 bean does not have any kind of MIDI compatibility so I shouldn't even think about it if I want that in the future, right?
so I got a USB cable and had absolutely no trouble using POD as a soundcard and doing exactly what I wanted to do before, thank you all very much!
btw: is there a list of what the amps/mods and  on the POD X3 are based on? Searched through the Advanced Guide, since the advanced guide in Pocket Pod includes the list so i figured that would be the same with the X3, but there's nothing there, and here the closest I found is this:
http://line6.com/support/docs/DOC-4602
but this is only a list of the models in X3 with their own names, nothing about their "inspiration"
thanks!
#9 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15626 posts
  • LocationOntario, Canada
  • Registered Products:15
Posted 03 June 2013 - 05:02 PM
btw: is there a list of what the amps/mods and  on the POD X3 are based on? .
http://l6c.scdn.line... Model Gallery (%20Rev%20B%20).pdf
  • 1
.... John Lennon
#10 luizmessora
luizmessora
  • 4 posts
Posted 04 June 2013 - 08:39 AM
thanks!
#11 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 6967 posts
  • Registered Products:6
Posted 05 June 2013 - 04:04 AM
I know you can not directly send MIDI commands to the X3 Bean, but what I wonder is if you can control Gearbox with MIDI, in essence indirectly controlling the X3.
#12 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17728 posts
Posted 05 June 2013 - 04:42 AM
i believe the answer is yes you can control gearbox via midi... and pod farm 2, but not pod farm 1.
I've not tested it personally, but seem to recall an upset user who didn't want to pay for pod farm 2 to get the midi functionality he had in gearbox.
#13 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 6967 posts
Posted 05 June 2013 - 04:53 AM
I remember those rants, I think it was more than one user too.
I know I have controlled the Gearbox plug-in and PF1 plug-in, but it was indirectly through Reaper's MIDI learn. I was able to successfully route any MIDI surface controller from my Yamaha S90es to any Gearbox or PF parameter, but I never tried to use it to control Gearbox as an editor.
#14 overmarssnew
overmarssnew
  • 1 posts
Posted 19 June 2017 - 02:44 AM
Bom Dia! Eu comprei muito na Internet, chegando a conclusão de uma linha 6 Tomou a iniciativa de bloquear a automação midi do POD X3, precisamente para evitar o uso de controles de terceiros! Minha pergunta é: até agora em 2017, não houve uma atualização do software que libere esse recurso? Pelo que eu percebi, a Linha 6 parou de produzir os POD's, mas insiste em mantê-los bloqueados para automação e uso ao vivo? Já não é produzido como tábuas do chão, pelo menos, o que se entende por visitar a página da empresa. Se algum puder responder, obrigado!
Also tagged with one or more of these keywords: x3, midi, m-audio uno, mac
