Convert .jam File To .wav Or Mp3/mp4
jam convert wav itunes youtube
18 replies to this topic
#1 jdkrueger
jdkrueger
  • 3 posts
  • Registered Products:2
Posted 16 April 2014 - 03:19 PM
I've saved recordings to the SD card and transferred them onto my desktop.  However I cannot figure out how to play them on my computer to play in iTunes or load them on to youtube.  I want to be able to play them other than on my amp.
I read the spider jam advanced guide and I didn't see anything that would help.
Please advise.
#2 gary9605
gary9605
  • 70 posts
Posted 17 April 2014 - 01:12 PM
These should be WAV file format. What you need is a utility that converts WAV into MP3. Do a google search for WAV to MP3 or whatever you need.
#3 jdkrueger
jdkrueger
  • 3 posts
Posted 17 April 2014 - 02:32 PM
They are not in WAV format. Is there a way to have them save as WAV? They are always .JAM files and do not play on the computer. Why are they JAM files? The above does not help.
#4 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2316 posts
  • LocationU.S.A.
  • Registered Products:16
Posted 17 April 2014 - 02:46 PM
You shouldn't need a converter. I'm pretty sure you can save your recording as a WAV file while the card is in the Spider Jam then you can import it into your DAW. After you record something or load a recording currently on the SD Card press the save button and then scroll down to look at your options, you should see something that says "Save recording as a wav file".
  • 1
"SoundCloud Playlist"
#5 jdkrueger
jdkrueger
  • 3 posts
Posted 20 April 2014 - 09:50 AM
OK i saw how to save it as a WAV file... however I get "Error writing to card"... meanwhile there is no issue saving it as a JAM file.  There is plenty of space on the card.  Still can't solve the issue
#6 Dedoxinator
Dedoxinator
  • 34 posts
Posted 29 January 2015 - 09:03 AM
Format your SD card in the Spider Jam first. Then do as Brazzy said. It will work fine.
  • 1
#7 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2316 posts
  • LocationU.S.A.
Posted 29 January 2015 - 09:19 AM
Another thing I've learned is that after I make a recording and save the wav file to the card I can just take the card out without powering the amp off. As long as I don't power off, the recording will remain in memory even if I reinstall the card back into the Spider Jam.
This is nice. Example, I make a few riffs I think might be good to use. Each time I make a riff and save it to the card I have to give it a new name by using the selector wheel. This can be a drag, lol.
So I make a few riffs name them accordingly starting with "0EW_RECO", "1EC_RECO", etc. I only change the first character 'cause it's quicker for me. When doing this I found out by mistake to not use characters like ": ; . ,", I forget which ones I used but when I went to read the card with my computer the file was corrupt, so I just stick to numbers or letters.
Hope this helps a little.
  • 1
#8 Dedoxinator
Dedoxinator
  • 34 posts
Posted 29 January 2015 - 10:48 AM
Good tip Brazzy. I have alays turned the amp off 'just in case', but will certainly use your method from now on.
#9 a1terrier
a1terrier
    Iknowathingortwo
  • PipPip
  • 144 posts
  • LocationWest Yorkshire, England
  • Registered Products:3
Posted 18 February 2015 - 10:50 AM
just in case you need a converter, I used to use Koyote. It was good and free.
#10 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2316 posts
  • LocationU.S.A.
Posted 18 February 2015 - 11:03 AM
Do you have the correct EXE file to share or the link to the correct program. That would be cool if it works. I gave up on that long ago.
#11 a1terrier
a1terrier
    Iknowathingortwo
  • PipPip
  • 144 posts
Posted 18 February 2015 - 11:23 AM
Hi
Just googled Koyote and it took me to cnet download site. Works ok, don't think it does Jam files tho
#12 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2316 posts
  • LocationU.S.A.
Posted 18 February 2015 - 11:35 AM
Hi
I understand, which is why I asked before I just go and install more programs. I've got to the point where I need to know as much as I can about a program before I just trust it. Thanks!
#13 a1terrier
a1terrier
    Iknowathingortwo
  • PipPip
  • 144 posts
Posted 18 February 2015 - 01:10 PM
No probs Brazzy. Think cnet is pretty safe. Koyote also good for converting backing tracks from Free guitar backing tracks to play on SJam
#14 richard0250
richard0250
  • 1 posts
Posted 04 April 2015 - 01:09 PM
To All the members on this forum about converting the MP3 to WAV files, i have been pulling out what hair I have left
over converting lesson files in to WAV files.
I have tried to many converters to say, all fail.
Today i found the best and easy free online converter that works very well,  :)  :)  :)  :)
the LINK   http://audio.online-.../convert-to-wav
i hope this will help all, i think the amp is very good, just don't understand why they would create it this way when MP3 is best
#15 wilhow
wilhow
  • 3 posts
Posted 01 May 2015 - 08:55 AM
Half way down the page is a j2wsetup,exe for JAM to WAV or visa versa.
http://www.hispasoni.../361562/pagina2
#16 Blubarb
Blubarb
  • 43 posts
Posted 08 May 2015 - 03:50 PM
G'day Brazzy et al. Not sure but I wonder if Audacity will do the trick. Brilliant for MP3 to .wav.
  • 1
#17 Ace_Handler
Ace_Handler
  • 6 posts
Posted 13 October 2016 - 11:18 PM
I've been using foobar2000 for years for all my audio conversions.  Using it right now to play .flac files via bluetooth to my 2.1 soundbar :-)  It too is free.  Will convert most everything on the planet.
#18 Ace_Handler
Ace_Handler
  • 6 posts
Posted 14 October 2016 - 05:51 PM
Just finished converting the Lawrence Fritt collection of blues backing tracks from 192kbps .mps to .wav mono with foobar2000 (total about 1.45 GB at nearly 5 hours playing time!).  I've uploaded a screenshot of the settings screen.  Just import the files into the foobar (drag & drop works fine) and right-click (after selecting all) and choose 'convert'.  The ...... at the bottom brings up the conversion options screen, choose your options.  I chose .wav; convert to source folder (I'll move them after); and in Processing, Downmix channels to mono.  Worked like a charm :-)
#19 lovemyspider23
lovemyspider23
  • 1 posts
Posted 21 October 2016 - 08:31 AM
Nothing on this page works please help jam to anything that will play my tracks from amp to anything else....
Also tagged with one or more of these keywords: jam, convert, wav, itunes, youtube
