Pod X3 And Gearbox (problem)
16 replies to this topic
#1 Punkyboy
Punkyboy
    Iknowathingortwo
  • PipPip
  • 262 posts
  • Registered Products:2
Posted 17 April 2014 - 12:28 PM
hello
I just change my device from Pod Xt to Pod X3
Everything is ok in the Line  6 Monkey and all is updated
But:
When I launch gearbox a window of "Hardware memory window is launching at the same time"
I don't see nothing in tonelocker window (on the right) it stay on connecting en empty
On the left I see the presets of the Pod x3
And I can not transfert from the right panel (because empty) to the left
e.g  copy and paste preset to another place
And i have a Pop up that say
"File operation could not be performed
Reason : 0xfe from the server Forbidden.
if you running a popup blocker or antivirus ......
And also if I load some preset I have a popup that say
"This tone require ;;;;;; update your POD X3 to 2.00 or higher ????
If I take a look in line 6 Monkey:
- The usb firmware is 1.02
- Flash memory is 2.00
- Gearbox is 3.72
And all is updated
I tried to uninstall and reinstall all , but it's the same
Can you help please ???
Line 6 Pod Hd 500X - Gibson The Paul II -  LTD Viper -  J&D Stratocaster Vintage - Line 6 Variax Standard
 Boss DR 670 - Line  6 EX 1 - Pigtronix Infinity looper - BeatBuddy
#2 BillBee
BillBee
    Power User
  • PipPipPipPip
  • 2453 posts
  • LocationMichigan
  • Registered Products:8
Posted 24 April 2014 - 07:27 AM
Hey There!
Is your problem similar to this: http://line6.com/sup...ew/thread/79910
I would give it a read as it mentions running the L6 License Manager.
If that doesn't help I would shoot an email to support due to the "update required" part.
-Bill
Smell the glove.
#3 Punkyboy
Punkyboy
    Iknowathingortwo
  • PipPip
  • 262 posts
Posted 24 April 2014 - 10:55 AM
Hello
Not really the same
Mine is
When I launch Gearbox,they are 2 windows, one the Gearbox, second the "hardware memory windows with all the tones of my Pod X3"
But In Gearbox, on the tonelocker on the right side I see nothing, it don't sync the right panel (in gearbox window)
Normaly you can see al the tones in your pod in the right panel ?? or Not ? with the Pod Xt it was no problem
But with the X3  it stay empty
But I need to use the other window,
And everytime, I must open a tone in gearbox and sync with the other windows (i mean the hardware memory window)
so for example
I need to open the tone in Gearbox >then I need to go to the other window (memory window) en sync
en every time you  change the presets you need to switch to the other window (memory window)
very boring!!
With the Pod Xt you could do everything in the same window of Gearbox!!!
Is this normal ???
Tx
#4 BillBee
BillBee
    Power User
  • PipPipPipPip
  • 2453 posts
  • LocationMichigan
Posted 24 April 2014 - 11:09 AM
Oooo I see what you mean. Its been too long for me to remember the X3 editing exactly but I want to say you are right, the way you have to do it currently does not seem correct. If you have the X3 setup right in 'preferences' and is updated correctly via Monkey it should work fine (should). The XTL fires right up in GB in one window.
Hopefully, someone more competent in this than me will come by and help.
Be sure to list your computer specs (OS, type) to aid anyone who comes by.
-Bill
Smell the glove.
#5 Punkyboy
Punkyboy
    Iknowathingortwo
  • PipPip
  • 262 posts
Posted 24 April 2014 - 11:20 AM
Tx bill
Yeah I check the update and also I uninstall all of line 6 and reinstal all, to be sure
And All is updated in Monkey and my device is authorized
Running on Windows 7 32 bits
#6 BillBee
BillBee
    Power User
  • PipPipPipPip
  • 2453 posts
  • LocationMichigan
Posted 25 April 2014 - 03:51 AM
Hey there (again) :-)
I've been looking at the older posts and such and there have been some people that had problems with Win7/Gearbox/X3.
Its crazy but if you had an old WinXP machine you could see how it runs on that. Does Win7 have an XP compatibility mode?
It must be driving you nuts. :blink:
Bill
Smell the glove.
#7 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 25 April 2014 - 06:09 AM
Win7 does have an XP compatibility mode.  It's most likely Java that is causing the problems.
#8 Punkyboy
Punkyboy
    Iknowathingortwo
  • PipPip
  • 262 posts
Posted 25 April 2014 - 09:16 AM
ooh I go check de java , maybe it's the reason
yeah Bill it drive me totaly nuts !!!!!
compatibility mode you mean in properties of Gearbox and let it run in win xp  mode??? I gonna try this way to!!!
#9 Punkyboy
Punkyboy
    Iknowathingortwo
  • PipPip
  • 262 posts
Posted 26 April 2014 - 03:32 AM
So I try and install and update Java
Compatibillity xp
and NOPES don't work
look at this pic with this link
https://app.box.com/...rxdr1ddn5xet3pe
#10 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2316 posts
  • LocationU.S.A.
  • Registered Products:16
Posted 26 April 2014 - 04:48 AM
Compatibillity xp
Do have an antivirus program installed? The window with the patches in it will always pop up when gear box starts that normal. I use and X3Pro with Gearbox. I never had the antivirus pop up though.
"SoundCloud Playlist"
#11 Punkyboy
Punkyboy
    Iknowathingortwo
  • PipPip
  • 262 posts
Posted 26 April 2014 - 04:56 AM
Yes I have malwarebyte's installed ??
But with the Pod xt I had the same antivirus but no problem with it !!!
Do you think I need to uninstall it or deacivited??
#12 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2316 posts
  • LocationU.S.A.
Posted 26 April 2014 - 05:03 AM
I think tone locker was like a cloud for storing tones. I never used it. I don't think it works any more 'cause it's not supported anymore, but I'm not really sure, I know guitar port doesn't work either. Can you use Gearbox now?
#13 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2316 posts
  • LocationU.S.A.
Posted 26 April 2014 - 05:08 AM
I did a little search and found an archived thread which may help a little. Here's a link
The first post below:
Was the gearbox tone locker issue ever solved?
by nokes on 2011-12-16 22:35:59
I just started having the problem of running gearbox, and not being able to access the tone locker.  I will get an error message that says 'please update to the latest version of gearbox' even though i am updated to the most current gearbox 3.72.  I also will get a different error message occassionaly that states "error communicating with the server... try again or contact tech support'.  I have heard of many others on the forums having this issue but i was unable to find a clear solution.
Please help.
kidnokes@yahoo.com
Edited by Brazzy, 26 April 2014 - 05:08 AM.
#14 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2316 posts
  • LocationU.S.A.
Posted 26 April 2014 - 05:17 AM
Check this archive too: Here's the link
Tone Locker Error
by grichardson on 2007-05-02 16:05:16
I'm experiencing problems connecting to the Tone Locker online with the error "File operation could not be performed. Reason: 0xfe from Server - Forbidden ..."
Others seem to have already reported this and in looking through their question's replies it went from it was a known bug to it had started working. So the only reason I'm reporting it again is if it was thought to have been fixed to let you know there are still problems out there.
For what it's worth I completely uninstalled Gearbox and deleted its files and any downloads it had. Then I reinstalled Gearbox and made sure with Line6 Monkey that everything was up to date - which it is. Also I have tried changing my default web browser from IE7 to the current Firefox with still no luck.
Thanks for your help.
#15 Punkyboy
Punkyboy
    Iknowathingortwo
  • PipPip
  • 262 posts
Posted 26 April 2014 - 09:49 AM
Tx Brazzy
that confirm that I had no problem with my Xt
But wel with my X3
So I hope that the Line 6 customers don't forget who make the history of Line 6  Pod's.I mean the buyers of the POD 2.0,xt and x3
And not really the buyer of the HD's that make maybe the actual history lol!!
And let we hope for a patch or update of Gearbox k,for the Old users
tx again
#16 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2316 posts
  • LocationU.S.A.
Posted 26 April 2014 - 10:20 AM
Tx Brazzy
But wel with my X3
tx again
Your Welcome PunkyBoy, I try to help when I can and I hear Ya on the recognition. I started and still have the GX, UX2, X3Pro, Spider Jam and now the HD500 and DT50 Head. I'm having a fun time learning how to use these things.
#17 Punkyboy
Punkyboy
    Iknowathingortwo
  • PipPip
  • 262 posts
Posted 26 April 2014 - 10:32 AM
That's fine man !!!
But maybe you can give me a tip on another question that I posted here :
http://line6.com/sup...42-purple-x-fx/
Tx again
