Direct Out To Pa
5 replies to this topic
#1 boloulu
boloulu
  • 20 posts
  • Registered Products:9
Posted 18 April 2014 - 05:21 PM
Can you still hear the DT 50/25 if the XLR line out is sent to the PA? On the Spider IV the line out cancels the speaker in the amp so a floor monitor is needed to hear oneself. Line out is a great feature to prevent mic bleed from other amplified inst and vocals.
#2 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2325 posts
  • LocationU.S.A.
  • Registered Products:16
Posted 18 April 2014 - 06:40 PM
I'm pretty sure you can do that. I ran the XLR out from my DT50 Head into a PA once but I had it in Standby and didn't try monitoring with the Speaker. I would try it for ya but my AMP is down at the moment.
#3 aeugle
aeugle
    Iknowathingortwo
  • PipPip
  • 153 posts
  • LocationMunich, Germany
  • Registered Products:6
Posted 19 April 2014 - 06:12 AM
Yes thats working. In standby mode there is no Signal.
#4 sonic
sonic
  • 43 posts
  • LocationHaacht, Belgium
  • Registered Products:2
Posted 05 May 2014 - 09:04 PM
unless you put it in Low Volume Mode...
Sammy
Line6 DT25 head and cab, Line6 HD500, Line6 JTV 59.
Marshall JVM 410H, 1960 AX cab.
Gibson SG Standard.
Steinberger GM 4S (Newburgh).
#5 aeugle
aeugle
    Iknowathingortwo
  • PipPip
  • 153 posts
Posted 07 May 2014 - 06:22 AM
Why is this ? Why only in low volume mode?
#6 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 8950 posts
  • LocationMinneapolis, MN
Posted 07 May 2014 - 07:09 AM
There have been some long threads regarding this here, but the way I see it is this. In full power mode, the signal going to the XLR out is being tapped from the output transformer so that the tube power amp affects the signal. In standby, the power tubes aren't operating, so this is why there's no signal.
In low volume mode, the signal going to the XLR out is simply the signal from the preamp section with cab and mic modeling applied. The power amp interaction is modeled rather than real. It still works in standby in LVM because the signal isn't dependent on the actual power tubes in any way.
