Analogs Out Problem
ux2 analogs output noise
Best Answer Triryche , 03 June 2013 - 05:03 AM
Definitely sounds like a connection issue. I currently cannot view your photos (dropbox blocked at my current location) so not sure what your adapters look like.
Can you hunt down a set of cable like these?
http://www.zzounds.com/item--HOSCPR20
Go to the full post
7 replies to this topic
#1 gianu
gianu
  • 7 posts
  • Registered Products:1
Posted 29 May 2013 - 06:40 PM
Hi!
I have a problem with the analogs outs of my UX2. After connecting the output to my Edifier R2600 I can only hear noises. I can see the VU meters moving with every sound of my computer, but I cannot hear those sounds I only hear noises.
I tested that the input of the edifier worked (connect the output audio of my computer directly to the Edifier).
I tested that the cable works.
I tested the analogs output individualy connecting a headphone, and it works!
But when I connect the ux2 to my edifier using the same cable, I can only hear noises.
Given that the cable is a RCA, I used two conversor from RCA to Plug to plug the cable to the UX2, the conversors are brand new (bought on a good audio store), could it be the problem? Or is something else that I'm missing?
Thanks for your help. :)
#2 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2576 posts
  • LocationNew England
  • Registered Products:3
Posted 30 May 2013 - 04:09 AM
Make sure you have RCA - MONO 1/4" plug adapters.  They should have just 2 conductors on the 1/4" plug. Make sure you have them plugged into the audio outputs of the UX2, as well! :)
#3 gianu
gianu
  • 7 posts
Posted 31 May 2013 - 03:28 PM
Thanks fflbrgst for the answer!
Yes I have two RCA - Mono 1/4'' plug adapters (image: https://dl.dropboxus...187032/plug.jpg) and they are both plugged into the audio outputs :) (https://dl.dropboxus...32/conector.jpg).
#4 gianu
gianu
  • 7 posts
Posted 01 June 2013 - 09:34 AM
Another thing that i found is that if the RCA cable are disconnected and I'm playing my guitar I can see the Vu Meter moving (but when I connect the RCA -with the adapter-) to the analog outs, the VU Meters stop moving.
#5 gianu
gianu
  • 7 posts
Posted 01 June 2013 - 10:13 AM
one more test that I made. If I choose the UX2 as my sound output device (in OSX Preference) when I press the volume up & down I can see the VU Meter moving, so the sound is going to the UX2, but I cannot hear anything from the Edifiers, just a "noise" (static noise I guess). If I move the output volume pot in the UX2 this "noise" is louder, so something seems to be sending. I'm clueless about this.
Any hint?
Thanks!
#6 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
  • Registered Products:6
Posted 03 June 2013 - 05:03 AM   Best Answer
#7 gianu
gianu
  • 7 posts
Posted 04 June 2013 - 04:21 AM
Well, I bought some of the cable that Triryche suggested and fixed the problem. Seems to be a problem with the adapters then.
Thanks for your help!
#8 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
Posted 04 June 2013 - 04:56 AM
Cool!!
Glad you got it sorted out.
btw, dig the your new avatar!!
Also tagged with one or more of these keywords: ux2, analogs output, noise
