pianojunky Posted April 24, 2014 Share Posted April 24, 2014 For some reason the amplifi app won't let me save to the amplifi. When in first had the amplifi it worked great, however, I haven't been able to 'save to hardware' for the past few weeks. Anybody else having this issue? Quote Link to comment Share on other sites More sharing options...
Triryche Posted April 24, 2014 Share Posted April 24, 2014 Are you pulling a tone from a match or my tones? I had this happen to me a few times, and it seemed like it was because I made no edits to the tone. Quote Link to comment Share on other sites More sharing options...
pianojunky Posted April 24, 2014 Author Share Posted April 24, 2014 I am pulling from my tones. Quote Link to comment Share on other sites More sharing options...
Triryche Posted April 24, 2014 Share Posted April 24, 2014 make sure you edit the tone first, otherwise the option might still be greyed out. I haven't had a chance to double check this yet. Quote Link to comment Share on other sites More sharing options...
pianojunky Posted April 24, 2014 Author Share Posted April 24, 2014 They are edited tones. The strange thing is the 'Save to Hardware' is not grayed out. It looks like I should be able to press it, but nothing happens. I think I'll go the route of deleting the app and reinstalling it to see if that will clear things up. Quote Link to comment Share on other sites More sharing options...
archtopeddy Posted April 24, 2014 Share Posted April 24, 2014 They are edited tones. The strange thing is the 'Save to Hardware' is not grayed out. It looks like I should be able to press it, but nothing happens. I think I'll go the route of deleting the app and reinstalling it to see if that will clear things up. May be a good idea to reinstall. Be sure to save any favorite tones by publishing them. Meanwhile, I just checked mine and I don't seem to be having your problems... most of the time. Just for the record, here's what happens when it works correctly (on my iPhone 4S): First, go to "My Tones" (where the Save to Hardware is grayed out) and pick the tone I want to use. It gets highlighted in red and the "Save to Hardware" lights up. I tap "Save to Hardware" and it takes me to the "Hardware" page and I select one of the four presets. It immediately changes name to the new tone with a red banner. When I hit "Done", a timer spins for a couple of seconds and a green banner appears quickly at the bottom of the screen with a message saying "Save to Hardware was successful to location XX". Now here's what strange... sometimes when I go back to my "AMPLIFIED 150" from the main page to see if the changes took hold. It shows the correct tone patches including the new tone but when I back-track to "My Tones", I can't get "Save to Hardware" to work with another tone. I think this sounds like the problem you're having. Sometimes the "Save to Hardware" is lit, sometimes it's not. Either way, it doesn't seem to work. I usually close the app, go to "Settings", double-check the bluetooth connection, do the hokey pokey and turn the app back on. Usually this fixes things. So... I think it's temperamental even when it's working correctly. Quote Link to comment Share on other sites More sharing options...
pianojunky Posted April 26, 2014 Author Share Posted April 26, 2014 Didn't delete and reinstall but it magically started working again. The only change is I updated my iPad. Quote Link to comment Share on other sites More sharing options...
Fkavka Posted May 1, 2014 Share Posted May 1, 2014 They are edited tones. The strange thing is the 'Save to Hardware' is not grayed out. It looks like I should be able to press it, but nothing happens. I think I'll go the route of deleting the app and reinstalling it to see if that will clear things up. I am having this exact same issue. I've tried from both my ipad2 and iphone4 and in both cases the "save to hardware" is not greyed out but nothing happens when I press it. All other functions of the app and amp work fine. The firmware is the latest version. Short of deleting and reinstalling has anyone found another solution?!? Thanks. Quote Link to comment Share on other sites More sharing options...
archtopeddy Posted May 1, 2014 Share Posted May 1, 2014 Try closing the app, going to "Settings", double-checking the bluetooth connection, turning the bluetooth connection off and back on again, and then turning the app back on. No promises, but sometimes this works for me. Quote Link to comment Share on other sites More sharing options...
bitmobruce Posted May 4, 2014 Share Posted May 4, 2014 I am having the same problem. Save to hardware only works very occasionally - mostly grayed out. I tried all of the above suggestions - nadda. Quote Link to comment Share on other sites More sharing options...
bitmobruce Posted May 10, 2014 Share Posted May 10, 2014 I solved the problem by downloading a newer version of the app. Works OK now. Quote Link to comment Share on other sites More sharing options...
