Fbv Express Mkii Expression Pedal Problem
4 replies to this topic
#1 swansonsuk
swansonsuk
  • 2 posts
  • Registered Products:2
Posted 25 April 2014 - 06:00 AM
Hi folks,
Wondered if you can help with a problem that has just started to happen on my pedal.
I have the above mentioned pedal attached to a Spider IV 150 and when I first bought it 6 months ago the expression pedal was controlling the volume and the wah respectively when pressing toe down to toggle between the functions.
I am now finding that the volume is not working and neither is the wah. When you select the wah it is switching on but regardless of how much I move the expression (heel or toe down) it is always on the toe down position.
I have gone through the calibration process of unplugging the pedal and then pressing down on button d while plugging it in but when I get through to the stage of moving the expression pedal up and down and the led's going up and down with the pedal they do not turn off accordingly.
I have done all of the updates and still nothing.
Thanks
#2 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2520 posts
  • LocationNew England
  • Registered Products:3
Posted 28 April 2014 - 04:14 AM
Sorry you are having problems - have you checked the settings on your amp?  You can adjust the heel & toe ranges in the edit mode.
#3 jorgensjolund
jorgensjolund
  • 1 posts
  • Registered Products:1
Posted 28 April 2014 - 10:30 AM
I have the exact same problem with my FBV Express and Amplifi 75. Cant find anywhere in the amp where i can do some editing.
#4 swansonsuk
swansonsuk
  • 2 posts
Posted 03 May 2014 - 01:24 PM
Hi folks,
I am well aware that I can adjust the effect ranges for the expression pedal through the amp but that is not the problem.
No matter what movement I I exert on the pedal it is always stuck on maximum toe down.
As mentioned I went through the calibration process () but at the moment where he shows the led lights going up and down my pedal stays fully lit.
Thanks
#5 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2520 posts
Posted 05 May 2014 - 05:09 AM
Unfortunately, it sounds like your pedal may need repair/replacement.
