Using External Preamp
3 replies to this topic
#1 Zhorell
Zhorell
    Iknowathingortwo
  • PipPip
  • 105 posts
  • Registered Products:2
Posted 30 May 2013 - 09:12 PM
Novice question here; will the Effects works with an external preamp hook up in the loop return? I'd like to use the Power (Bogner) section with a tube (randall rm4) preamps..
If not? is there a way to bypass the digital amp modeling? connecting into guitar input to utilize the effects?
#2 napynap
napynap
    Iknowathingortwo
  • PipPip
  • 284 posts
  • LocationPalmdale, CA
  • Registered Products:4
Posted 05 June 2013 - 08:01 PM
Please specify which SV you have. I will only comment on the SV MkII (Bogner) here.
1st and 2nd question: No, the effects will be bypassed.  [Edit from SV MkII Pilot guide, #14: Power Amp In – ...You can then use the POWER
AMP IN either as an input from another preamp or multi-effects unit like the POD X3 Live or as a “series effects return”.]
3rd question: Anything connected to the guitar input will utilize the tube preamp and effects. It's ok to connect guitar style pedal effects to this jack (like distortion, wah, etc..)
#3 jws1982
jws1982
    Iknowathingortwo
  • PipPip
  • 315 posts
  • Registered Products:5
Posted 10 June 2013 - 12:42 PM
napynap's right.   Sounds like you'd be a good candidate for an M13 effects board.
#4 sopesz
sopesz
  • 1 posts
  • Registered Products:1
Posted 12 April 2014 - 09:56 PM
Hello! I like to know some technical parameter. I want to connect Gt8 multieffekt with "4 wires" and optimalize signal levels.
Please write for me:
Spider Valve MKII 100HD
Input level: ?dBu
and Impedance: ? Ohm
Pre out ?dBu, and imp.?Ohm
Power amp in ? dBu and imp
Thanks!
