Connecting Pod 2.0 To Monkey Problems
monkey pod 2.0 midi
13 replies to this topic
#1 tuckwatts
tuckwatts
  • 2 posts
  • Registered Products:1
Posted 26 April 2014 - 06:46 PM
I have tried this over and over.  Ok so I just got a brand new POD 2.0 and the online guide and such said it would come with software and a cable to connect to my computer and it didn't but that's not the real issue (just a frustration).  I bought a MIDI cable and connected it properly (MIDI Out cable to MIDI In on the device and MIDI In cable to MIDI Out on the device) and also vice versa just to see if it would work.  I am trying to connect to Monkey to be able to check for updates and also to locate the device on my computer so I can eventually use Line 6 Edit.  So I boot up the program (picture 1) and check the top list for POD 2.0 and it is not there (picture 2).  I then click the second option and selected POD 2.0 from the drop down box (picture 3).  I also tested all 3 options that are in the MIDI Out drop box (picture 4) and every single one gave me the message in Picture 5.  I went ahead and clicked OK (I have tried proceeding with all 3 options) and moved on to picture 6.  I click on update selection and went through all the stuff it tells me to do including turning off POD 2.0 pressing and holding the MIDI button then turning it back on.  The POD 2.0 display showed "F" and a flashing dot next to it.  It then shows the error from picture 7.  I have no idea what to do there are literally no instructions that came with the device and I don't know what else to do.  Please help.
#2 Bendad
Bendad
  • 2 posts
  • Registered Products:3
Posted 27 April 2014 - 12:32 AM
Sorry I can't help but I am in the same position but with one extra day of frustration!
I have contacted Line 6 and if I get a result I will let you know.
#3 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 27 April 2014 - 03:29 AM
http://line6.com/sup...de-and-faq-r444
I'M SO HAPPY!
#4 BillBee
BillBee
    Guru
  • PipPipPipPipPip
  • 2531 posts
  • LocationMichigan
  • Registered Products:8
Posted 28 April 2014 - 04:24 AM
Lets get some more info.Though to be honest you should be able to use L6Edit regardless of the Flash - unless your PC and L6Edit aren't configured correctly.
Version of Pod? The older Pod 2.0's will not update via Monkey, only by upgrading the Chip. Does it say "Pedal" or "FBV" where the pedal jack is? If it says "Pedal", it is an older version and cannot be upgraded by Monkey.
Type of Midi/USB cable? Brand name? (please don't say the cheap chinese ones).
OS system?
When you connect to L6Edit what happens? Messages? How do you have the MIDI preferences set up?
If you do have the PodV2 FBV version you could try updating the flash memory "offline" you can DL it off the DL page:
Requires v2.5 or higher (POD 2.0 2006 FBV edition)
This resolves a problem with the transfer of single POD patches between units via MIDI. Previous releases did the following:
- enabled FBV2 Foot Controller support (2.53)
- resolved the inability to Save and Recall Channels and Amp Model defaults with customized Cab pairings. (2.52)
Please use Line 6 Monkey 1.15 to perform the update (a MIDI interface is required).
If your current firmware version is 2.2 or earlier, please see the text for version 2.3, as an eprom update is required (no updatability via MIDI is provided.)
OS: Windows XP, Windows 2000, Windows ME, Windows 98SE, Mac OS X, Mac OS Tiger, Windows Vista, Mac OS Leopard, Windows 7, Mac OS Snow Leopard, Windows 8
( 80.22 KB ) Get Download
Smell the glove.
#5 tuckwatts
tuckwatts
  • 2 posts
Posted 28 April 2014 - 05:15 PM
I have the FBV version.  I don't think the MIDI is a cheap chinese one as it took only 2 days to ship instead of 2 months like the last piece of garbage I ordered from China.  My OS is Windows 7 Service Pack 1.  When I try to connect to L6Edit my device just doesn't even show up via MIDI.  Someone else told me I needed to use a USB to 1/4" to connect to L6Edit which frustrated me more and confused me.  I will try the offline update and see if it works.
#6 BillBee
BillBee
    Guru
  • PipPipPipPipPip
  • 2531 posts
  • LocationMichigan
Posted 29 April 2014 - 03:13 AM
Well shipping times don't necessarily equate to the mfg of the cables but if you can get them to work its all good.
Did some searching and found this: http://line6.com/sup...7DE71E?tstart=1
I'm still using WinXP so I can't tell you much about Win7 but the few threads I came acrossed point to a Java issue.
L6Edit shows your midi interface under the preferences for the ins/outs so that's a start.
Smell the glove.
#7 Mr_Arkadin
Mr_Arkadin
    Guru
  • PipPipPipPipPip
  • 2817 posts
  • Registered Products:6
Posted 29 April 2014 - 01:16 PM
If you have a no-name USB to MIDI device you can pretty much guarantee that's where the problem lies. I would try the recommended MIDISport Uno.
#8 onelung
onelung
  • 2 posts
Posted 01 June 2014 - 01:45 PM
This is frustration at its finest.  I'm having the same problems as described above.  My Pod is an older one - it says PEDAL above the rj45 connector. I've been scouring the internet from front to back for some answers to no avail.  Surely SOMEONE has the solution.  I realize an older POD 2.0 may not interface correctly with newer operating systems, but if that's the case, maybe someone at Line 6 should address this problem.  I can't obtain an EPROM card, and Monkey won't update my flash memory.  What gives?
#9 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 03 June 2014 - 03:08 PM
  • 1
I'M SO HAPPY!
#10 Bolocho95
Bolocho95
  • 1 posts
Posted 06 June 2014 - 09:16 AM
Same problem than you!
I have tried many things, but none of them works... I have read that the flash memory is not important in POD 2.0, however, when I open my Line 6 Edit, it doesn't recognize my POD. How can I see if my MIDI- usb is working??
#11 BillBee
BillBee
    Guru
  • PipPipPipPipPip
  • 2531 posts
  • LocationMichigan
Posted 09 June 2014 - 06:08 AM
Hey Fellas,
Yes it can be a major pain but 9/10 it is the midi->usb cable or an os issue. For ex. WinXP can actually have too many usb hub/devices instances (iirc) it only allows for a finite amount. I had to go through the Device Manager and scour them out (30+) to get the ole trusty FPP connected again. If it is an OS system higher than WinXP I can't offer much help other than to try compatibility mode (?).
The Pod 2.0 will connect but get some good cables.
When you do a search here for Pod 2.0 connection problems the majority of issues are solved with quality USB/Midi cables.
-B
Smell the glove.
#12 onelung
onelung
  • 2 posts
Posted 09 June 2014 - 10:21 AM
I'm trying to connect with the M-Audio Midisport UNO cables.  I'm running Windows 7, but I also set up my old computer that has Windows XP on it.  It won't connect to the Pod either.  I even had a friend try the cables on his POD 2.0 and his connected with no problems, so it's not the cables.  I'm ready to give up.  By the way, what is compatibility mode?
#13 BillBee
BillBee
    Guru
  • PipPipPipPipPip
  • 2531 posts
  • LocationMichigan
Posted 09 June 2014 - 11:30 AM
Try it on your old XP computer with the ins/outs reversed and there are some utilities on the MAudio site which would help you. It could be a PC problem did you try and connect your pod on your friend's pc? L6Edit should "see" the cable for the ins and outs. There is a bit of a help section (IIRC). But really head to the MAudio site and check for new drivers - PITA I know - but the pods usually connect to the XP systems.
Compatibility mode = let's the OS "downgrade" itself to run a program (simplfied explaination).
-B
Smell the glove.
#14 goyovista
goyovista
  • 1 posts
Posted 13 September 2015 - 12:20 AM
I had the same problem. Re-downloading Line 6 Monkey from the home page fixed the problem.  http://line6.com/software/
Also tagged with one or more of these keywords: monkey, pod 2.0, midi
