Dt25 Replacement Fuse, Need Correct Link Please!
8 replies to this topic
#1 loser7787
loser7787
  • 20 posts
  • Registered Products:7
Posted 28 April 2014 - 02:05 PM
Hi guys,
My DT25 stopped outputting sound recently. I thought it was something different because it happened immediately after updating the firmware to 2.00. After downgrading and checking wires/connections I tried the direct out into my toneport and it worked fine. Upon further inspection I found the tube protection fuse is fried. I understand this usually happens when a tube goes bad but I took the back panel off and there is no sign of tube being blown out or damaged. No discoloration or anything like that. I figured I would order a few fuses and if it blows again I will replace the tubes.
Problem is I cant find the exact fuse I need. There were 2 forum posts here with the right fuses but going back they are all crossed out and saying they are in fact not the correct fuse. To my understanding I need a .375 Amp / 375 Milliamp 250v Slo Blo fuse. Can someone please send me a link or two where I could purchase these just so I don't need to wonder if i'm in fact buying the correct fuse. Any help/comment is appreciated.
Thanks.
#2 loser7787
loser7787
  • 20 posts
Posted 05 May 2014 - 09:02 AM
Anyone, please!
I am really hurting not having my DT up and running. Obviously people here have ordered replacement fuses. Just need a link to the correct tube protection fuse.
Please and thank you!
#3 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 05 May 2014 - 09:12 AM
i recommend calling: http://line6.com/company/contact/
any info you get on here may not be as accurate as you'd like...
meaning that the fuses can vary by your region of the world and what you are feeding into your amp.
#4 loser7787
loser7787
  • 20 posts
Posted 15 February 2015 - 09:15 AM
I know this is awhile later but just trying once more. Just playing with the HD500 direct to some monitors has sounded great and delayed me attempting to replace the fuse.
Finally think I'm going to call Line 6. I am located in the US if that helps find the correct fuse. I am reading about people replacing the tube protection fuse. Does anyone have a link for DT25 replacement fuse. I just got my JTV and I am itching to get the dream rig up and running.
Would this work? http://www.amazon.co...o/dp/B00LQPQ1EC
I am finding .375 Amp 250v slow blow fuses but some of the picture show a smaller looking fuse than I need.
Any help is appreciated.
Thank you.
#5 DarrellM5
DarrellM5
    Gear Head
  • PipPipPip
  • 929 posts
  • LocationRound Mountain, NV
  • Registered Products:5
Posted 15 February 2015 - 12:34 PM
Okay.  Here's what I bought.
Bussmann MDL-3/8
I got them through ebay.  Here's a link to a similar deal:
http://www.ebay.com/...=item5d552520db
I bought the other fuse from Radio Shack P/N 270-1064
#6 innovine
innovine
    Iknowathingortwo
  • PipPip
  • 322 posts
  • Registered Products:2
Posted 16 February 2015 - 07:50 AM
Anyone know if a 400mA fuse is close enough? Screw line6 for using such an obscure value on a wear-n-tear component.
#7 innovine
innovine
    Iknowathingortwo
  • PipPip
  • 322 posts
Posted 04 March 2015 - 01:04 PM
I still didn't find an easy source for the fuse, so I put in a 315mA fast one instead. Seems to work ok so far :)
#8 geppert
geppert
    Iknowathingortwo
  • PipPip
  • 369 posts
  • LocationWest Coast, Canada
Posted 04 March 2015 - 01:56 PM
Having gone through all this ..... and From My thread below ....
http://line6.com/sup...dt25-head-dead/
The tube protection fuse is the tough one to find ... the line fuse is pretty much available at any guitar shop.
The actual Tube Protection fuse I have in my DT25 (375mA/250V Slo Blo) is a LittelFuse 0313.375
Mouser Part # 576-0313.375MXP
Manufacturer: LittelFuse
Manufacturer Part Number: 0313.375MXP
http://ca.mouser.com...4H0c833ETykqA==
The Bussmann MDL 3/8 is an equivalent.
Mouser Part Number: 504-MDL-3/8
Manufacturer: Eaton
Manufacturer Part Number: BK/MDL-3/8
http://ca.mouser.com...Tq0cGO5NIGsxA==
  • 2
#9 loser7787
loser7787
  • 20 posts
Posted 19 May 2015 - 09:20 AM
Thanks guys! I did call line 6 about a month ago and they gave me a part number and a site to get it from but the part number didn't come up at all ha. I just ordered from the mouser links posted above. Hoping it was indeed just a blown fuse and not the tubes failing but I ordered a few extra just incase. Thanks again for the input!
