What Causes The Increased Volume On This Patch
lincoln brewster preset patches pod hd500x hd500
Best Answer gunpointmetal , 01 May 2014 - 01:21 PM
There's another thread around here that explains basically, that the L/R aren't really left and right, but two stereo signals you can balance however you like (may not be 100% accurate!) and so putting both of them at center gives you a boost of somewhere around 6dB (may not be accurate!) in volume over "stock" patches with everything panned all the way out.
Go to the full post
9 replies to this topic
#1 alienux
alienux
    Iknowathingortwo
  • PipPip
  • 273 posts
  • LocationDayton, Ohio
  • Registered Products:1
Posted 01 May 2014 - 12:02 PM
I downloaded Lincoln Brewster's official HD500 presets from here
http://www.lincolnbr...com/podpatches/
And specifically, the one named Lincoln_Brewster_Main_2012.h5e
For some reason, this preset is much much louder than any preset I create myself without messing too much with the volume settings.
I've turned off every effect/amp block and checked all of the levels, including DEPs and none are really any different than any settings I use in my patches, and this patch is still much louder than any of my patches.
The only difference I can see is that at the mixer he has both R and L set to Center instead of the default !00% Left and 100% Right. Changing that makes some difference, but it seems like the volume difference is more than just that.
I also changed the extension to .5xe to import on my HD500X. That shouldn't make any difference, should it?
Is there something else I'm missing, or does centering the Mixer block actually really make that much difference in overall volume without actually changing any volume parameters?
  • 1
brian ®
http://brianmhall.wordpress.com - Guitars & Gaming
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 8949 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 01 May 2014 - 12:19 PM
Well, some of the amp models are just louder than the others, and the difference is quite significant between some of them.
#3 stumblinman
stumblinman
    Gear Head
  • PipPipPip
  • 882 posts
  • LocationPacific Northwest
Posted 01 May 2014 - 01:04 PM
Recreate it yourself block by block, parameter by parameter and see what you get.
  • 1
#4 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1089 posts
  • Registered Products:3
Posted 01 May 2014 - 01:21 PM   Best Answer
  • 2
#5 alienux
alienux
    Iknowathingortwo
  • PipPip
  • 273 posts
Posted 02 May 2014 - 05:00 AM
I didn't do exactly that, but like I said, I turned off every block on the patch. I then turned each one on one by one, but none of them made that much difference.
"gunpointmetal"
That makes sense with what I found after turning off all of the blocks. I knew about the L/R being two separate stereo signals, but I had no idea that centering them would give such a big boost.
brian ®
#6 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2325 posts
  • LocationU.S.A.
  • Registered Products:16
Posted 02 May 2014 - 05:18 AM
The mixer as simple as it looks can manipulate the sound more than you might think at first. You can pan center on path A and mute path B to get just path A, or vica versa or use both channels panned center for the loudest output, etc. Whenyou download a tone check out the mixer settings first so you know where you stand, before you possibly blast yourself with sound.
  • 1
#7 alienux
alienux
    Iknowathingortwo
  • PipPip
  • 273 posts
Posted 02 May 2014 - 05:26 AM
Thanks, that's good to know. I was surprised at how loud this one was when I first tried it, but thankfully I didn't have headphones on at the time.
brian ®
#8 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
  • Registered Products:5
Posted 05 May 2014 - 02:29 AM
check out this one:
Pod Hd 500 - 500x *new* Routing Schematics
#9 alienux
alienux
    Iknowathingortwo
  • PipPip
  • 273 posts
Posted 05 May 2014 - 05:16 AM
check out this one:
Yeah, I actually had set the second input to "variax" for this patch after downloading it, and it's still much louder than any patches I've created. I think it was mostly due to the centering in the mixer.
brian ®
#10 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
Posted 05 May 2014 - 05:43 AM
i think the quoted post clearly explains how the pod actually handles the signal...
Also tagged with one or more of these keywords: lincoln brewster, preset, patches, pod, hd500x, hd500
