nlabat Posted June 1, 2013 Share Posted June 1, 2013 Hi guys i need to use MY pod through the usb with the garage band but without any processing. I need to use the pod to record the flat and natural sound of my bass I will appreciate your advise. Regards Nico Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted June 1, 2013 Share Posted June 1, 2013 what pod do you have? All you have to do is plug it in and go... typically... assuming its a pod xt/x3/hd any older pod you will probably need an interface (as in the older pods won't do what you want) Quote Link to comment Share on other sites More sharing options...
nlabat Posted June 2, 2013 Author Share Posted June 2, 2013 what pod do you have? All you have to do is plug it in and go... typically... assuming its a pod xt/x3/hd any older pod you will probably need an interface (as in the older pods won't do what you want) I got BASS PODxt Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted June 2, 2013 Share Posted June 2, 2013 should still work fin with the drivers installed, might be as simple as engaging the tuner to disable processing... i don't have a bass pod xt and never have so i can't be any more specific. Quote Link to comment Share on other sites More sharing options...
Triryche Posted June 11, 2013 Share Posted June 11, 2013 Check the Line6 Audio-MIDI control panel. I know for the PODxt there is an option to send only the unprocessed signal to your DAW, not sure if that option is available for the Bass PODxt. Quote Link to comment Share on other sites More sharing options...
