grahamm Posted May 3, 2014 Share Posted May 3, 2014 Hi I have only had the HD500 about a week but I cannot seem to navigate around the user presets and set lists etc without having to connect my laptop and use the HD 500 Edit . Is that normal as I cant see anyway of navigating as it seems if I am in SET LIST 1 for example I can switch between only those patches only and not bank up or down into the other set lits or fixed presets via the pedal board or the Home screen ? Help? Apologies in advance if I am being thick All the best G Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted May 3, 2014 Share Posted May 3, 2014 that's normal, you need to work within a single setlist. you can change setlist on the unit by pushing the button left of the screen twist to select and hit enter on the desired setlist. Quote Link to comment Share on other sites More sharing options...
grahamm Posted May 4, 2014 Author Share Posted May 4, 2014 Thank you all again! Quote Link to comment Share on other sites More sharing options...
