Disable Volume Pedal, Volume Question.
1 reply to this topic
#1 robdot
robdot
  • 24 posts
  • Registered Products:3
Posted 04 May 2014 - 04:46 PM
I have a 3 piece classic rock band, I'm using a spider 4 75 watt with short board. My question is can I disable the volume pedal on the 75 watt amplifi like I can on the spider 4 ?
It's really annoying to step off the wah and then have control revert to the volume pedal at a gig. On the spider 4 you can set the min and max for the volume pedal essentially disabling it. It would be even better if there was simply a way to disable it completely.
I also have the spider 4 75 watt never turned up louder than 10 o clock. It's plenty loud for bars at that setting ,the way I have the channels set.. Can the 75 watt amplifi compare with that? ...anyone have any experience with that?
#2 dfdfan
dfdfan
  • 5 posts
  • Registered Products:1
Posted 13 May 2014 - 12:26 PM
Yes you can. Simply turn it off in the app, but you will need to do so for all patches where you want it disabled. There is no global disconnect.
