4cm With Power-amp
hd500
3 replies to this topic
#1 lou_kuehl
lou_kuehl
  • 11 posts
  • Registered Products:1
Posted 23 April 2013 - 09:18 PM
Hello,
I'd like to place the power-amp from a marshall into the FX loop block, do I just run the speaker cable from the amp into FX return on HD?
Good call gentlemen,
Most would say ignorance is stifling, I find it liberating. I was thinking about the sig chain. When using a full amp the mods come after power amp (I would think this better for plugging into line level/-10db?) When using pre-amp, mods are before power-amp (I would use +4db amp setting?). Now back to my ignorance, which chain is most practiced?
#2 IncredibleOLF
IncredibleOLF
  • 1 posts
  • Registered Products:7
Posted 24 April 2013 - 01:36 AM
dont do this !!! - it will sure kill your POD...!! search for infos on the 4CM and howto...
  • 1
#3 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 24 April 2013 - 03:47 AM
"http://line6.com/support/docs/DOC-2112">http://line6.com/support/docs/DOC-2112
for more info, go to top right hand corner of the page and select SUPPORT. then go to KNOWLEDGE BASE. then scroll to CHOOSE A FORUM. then select POD FORUMS. the select POD HD. from there you can select USER DISCUSSIONS or DOCUMENTS.
but there must be an easier way to get there, i just don't know how</p>
I'M SO HAPPY!
#4 jimsreynolds
jimsreynolds
    Power User
  • PipPipPipPip
  • 2250 posts
Posted 26 April 2013 - 05:03 AM
Listen to IncredibleOLF!    If you plug your power amp into your POD using the speaker jack you will destroy the pod.
I think you are misunderstanding how 4CM works.   Take a look at the document here for more information -->  http://line6.com/support/docs/DOC-2522
What you can do is plug your pod into the power amp input.  This is a standard setup with POD, used with the 'Combo Power' and 'Stack Power' modes.
  • 1
Also tagged with one or more of these keywords: hd500
