Sonic Port 1/4" Mono/stereo Output
6 replies to this topic
#1 wjmcl
wjmcl
  • 4 posts
  • LocationMadison, Wisconsin
  • Registered Products:4
Posted 01 June 2013 - 07:15 AM
I currently use a POD HD300. In "Dual" output mode I send the left 1/4" output to a custom Fender Pro Jr. on stage and the right 1/4" output to the FOH PA. I'm interested to know if the 1/4" Mono/Stereo output of the Sonic Port could be used in the same manner using an insert cable. Also, my favorite sound from the HD300 is "High Strung". Is that sound available to be included in the Sonic Port?
Thank you.
#2 timothybaugh
timothybaugh
    Iknowathingortwo
  • PipPip
  • 189 posts
  • Registered Products:12
Posted 02 June 2013 - 02:31 AM
I think the App the Sonic POrt uses to generate guitar tones is based upon the POD 2 so you get 32 amps and 16 effects. Not directly compatible with the HD range.
#3 wjmcl
wjmcl
  • 4 posts
Posted 03 June 2013 - 04:18 AM
That would be a disappointment. Thanks for the reply.
#4 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 03 June 2013 - 04:40 AM
I'm pretty certain that i'd asked this question and have gotten confirmation that you are correct.
the processing power needed for the HD models exceeds the capabilities of the apple products, especially if you want to also run things like garageband etc...
I have to say though. the models are quite serviceable and work well despite the age of the technology.
#5 mr_slugworth
mr_slugworth
    Iknowathingortwo
  • PipPip
  • 440 posts
  • Registered Products:2
Posted 03 June 2013 - 07:20 PM
So it's using POD 2.0 tech...  Is it possible to import POD 2.0 patches into the Mobile POD app?
#6 wjmcl
wjmcl
  • 4 posts
Posted 06 June 2013 - 04:45 PM
Does anyone have any thoughts about the other part of my question concerning the stereo line out on the Sonic Port? I'm referring to whether or not that output could send a signal to an on-stage amplifier AND the FOH PA using an insert cable? If that would work then the issue would be could I create a sound using Pod 2.0 technology that is adequately similar to a particular patch I like on the HD300. Thanks for any thoughts.
#7 siktracy
siktracy
  • 2 posts
  • Registered Products:3
Posted 12 August 2014 - 10:25 AM
I have used an insert cable to plug into the left and right channels of an amp so it should work for sending one signal to an onstage amp and the other to the PA.
