Pod Hd500x Best Way To Get Sound Out Of It
pod hd500 pod hd500x
7 replies to this topic
#1 normanmolina
normanmolina
  • 4 posts
  • LocationCanoga Park
  • Registered Products:1
Posted 05 May 2014 - 08:46 AM
Hey All!
Just got a new POD HD500X and I'm really eager to use it as much as possible but I have a few questions before I do. Before the POD HD500X all I had was a few pedals in front of my Peavey 15 watt combo amp, for home use or small gig use it was fine as I would mic it and get a decent sound. Now, when I'm at home I'd like to plug it in but when I put it through my little practice amp it sounds horrible as the amp has presets that you can only modify not take off. So, my question is for home use, small gigs, and big live use, what would be the best way and most affordable way to get the sound out of the POD?
Thanks!
#2 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 05 May 2014 - 09:49 AM
Maybe a set of Monitors is the best way.  It won't sound like your amp though without some tweaking.
#3 MIKEY9966
MIKEY9966
    Iknowathingortwo
  • PipPip
  • 177 posts
Posted 05 May 2014 - 10:49 AM
Well I went trough a lot of amps and I found what works best hands down, get you self a good pair of studio monitors with a flat response, wow what a difference in the sound
  • 2
#4 normanmolina
normanmolina
  • 4 posts
Posted 06 May 2014 - 08:44 AM
Would any of these do the trick?
#5 radatats
radatats
    Power User
  • PipPipPipPip
  • 2317 posts
  • LocationOrange County, NY
  • Registered Products:3
Posted 06 May 2014 - 09:04 AM
the studio monitor option is great for at home but not suitable for playing out or regular gigging...  You didn't really define what affordable is for you... If your wallet can afford it a pair of L2t's would be awesome.  At lower price points people have been happy with powered monitors.  These can be failrly easy to lug around and at bigger venues you can put your main tones through the house PA and use your powered monitors as a backline or personal monitor.  Of course you can also go the DT route and that works amazingly well too...
Pair of studio monitors (6-8") - around $300-500
Pair of 12" powered monitors - around $500
Single L2t - around $800
DT combo - around $1000
All these options can sound amazing and each has its own attributes.  You need to really define what you expect to be able to do with your rig and how much you can spend and go from there.  You don't really have to have stereo sound so a single quality speaker will work and you can always add a second later.  Buy the best you can afford and you will usually be happy with the result.
  • 1
#6 normanmolina
normanmolina
  • 4 posts
Posted 06 May 2014 - 08:59 PM
Thanks for breaking it down for me man!
I believe I will go with the powered monitors as this seems more viable in terms of finances and use.
one more question, what does DT mean?
#7 radatats
radatats
    Power User
  • PipPipPipPip
  • 2317 posts
Posted 06 May 2014 - 09:10 PM
Digital Tube?
http://line6.com/dt25/
#8 smrybacki
smrybacki
    Gear Head
  • PipPipPip
  • 669 posts
  • LocationCarlisle, PA
Posted 07 May 2014 - 07:09 AM
Line6 makes a series of hybrid amps called the DT Series.  DT25, DT50 etc...
However you play music using whatever gear you may choose that day-- the JOY of making it is the heart of it.
Also tagged with one or more of these keywords: pod hd500, pod hd500x
