the29band Posted May 7, 2014 Share Posted May 7, 2014 I recently bought the DT25 head/cab combo and I also have the HD500. When using the L6 Link, it makes loud pop noises when i change the preset on the HD500 (or the edit software). Both the DT25 and the HD500 are on the latest firmware. I am concerned about these pops in a live situation especially when the amp is mic'd. Is this just my amp or is this a common problem? If it is indeed a common problem, how do you deal with it? I did some search and looks like most folks are getting these pops when they change from Class A -A/B or vice versa but in my case I get it regardless Thanks for your help in advance! Quote Link to comment Share on other sites More sharing options...
the29band Posted May 7, 2014 Author Share Posted May 7, 2014 No this is not the same as I'm using a Les Paul. Happens with any guitar that I plug in. Quote Link to comment Share on other sites More sharing options...
the29band Posted May 7, 2014 Author Share Posted May 7, 2014 Anyone? Thanks! Quote Link to comment Share on other sites More sharing options...
edstar1960 Posted May 9, 2014 Share Posted May 9, 2014 Are you on the latest firmware for both the DT25 and the HD500 ? If yes, then I suggest a reflash of both and see if that changes anything. If problem remains then contact Line6 support and open a ticket and they will help you get to the bottom of it. Good luck. Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 9, 2014 Share Posted May 9, 2014 If you're switching from one topology to another or switching class - anything where one of the relays is firing - there can be some noise. Also, though, if you're changing presets when connected to HD Edit, that could be making things worse, too. Does it make a difference if you're connected to Edit or not? Quote Link to comment Share on other sites More sharing options...
jegler Posted July 28, 2014 Share Posted July 28, 2014 I had the same popping noises upon switching patches with my dreamrig. upping the JTV firmware to 2.1 solved those problems. Quote Link to comment Share on other sites More sharing options...
