Changing Spidervalve (not Mkii ) Preset With Boss Gt. Is It 10 Possible?
4 replies to this topic
#1 Kapa
Kapa
  • 2 posts
Posted 10 May 2014 - 06:26 PM
Hello guys!
I was wondering: if i bought one of those RJ45 to midi adapters, would i be able to change presets in my Spidervalve ( the old version ) with my boss gt 10?
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9052 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 10 May 2014 - 06:56 PM
No, it doesn't work that way. The FBV controllers are the only way to control the Spider Valve.
  • 2
#3 Kapa
Kapa
  • 2 posts
Posted 12 May 2014 - 07:37 AM
That's bad  <_<
I wanted to combine the GT10 effects with the spider valve amp sounds... :wacko:
#4 SSstormtrooper
SSstormtrooper
    Iknowathingortwo
  • PipPip
  • 158 posts
  • LocationCanada
Posted 04 July 2014 - 02:26 AM
Hello guys!
I'm pretty sure you could have some basic function if you went midi to midi. BOSS to SpiderValve, but maybe your SV mki doesn't have midi (I can't recall as I have the HD100 mkii).
It would only be a basic patch up or down and bank up or down anyways I'm guessing unless you really programmed some in-depth CC changes.
EDIT: It would only work for mkii amps as the mki's don't have midi as I kinda thought. Maybe try and find a good used fbv shortboard.
#5 SSstormtrooper
SSstormtrooper
    Iknowathingortwo
  • PipPip
  • 158 posts
  • LocationCanada
Posted 04 July 2014 - 02:37 AM
That's bad  <_<
You could still run the GT-10 in stompbox mode and run it into the front of your SpiderValve. You might have to disengage the preamps in the GT-10 to get the best sound that way so you're not having dueling preamps.
The best would be probably just use a nice clean sound on your amp and then use the BOSS for all the other dist effects and what not.
