Duoverb Question
8 replies to this topic
#1 irobot
irobot
  • 7 posts
  • Registered Products:2
Posted 01 June 2013 - 06:51 PM
Hi All
I recently procured a used (like new!) condition Duoverb amp head.
My question - Is it normal to have drops in volume when switching between the different amp models?
(Like when switching from one of the big Marshall amps down to a Fender tweed) I'm familiar enough with Line 6 amps to think the answer is yes, but would like to get some responses from the other users out there.
Thanks!
-Mike
#2 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
  • Registered Products:1
Posted 02 June 2013 - 02:48 AM
i will assume yes. because if i change patches on my pod, and not having saved that patch with the volume lowered, i get a scary loud volume increase most times. that's the way line6 has the volume stored on presets. why. i don't know. you would think they would have them set at a lower volume. by the way good choice of equipment,  :)
I'M SO HAPPY!
#3 sliding_billy
sliding_billy
    Iknowathingortwo
  • PipPip
  • 141 posts
  • Registered Products:10
Posted 03 June 2013 - 12:18 AM
In my experience with the DV (I currently have one, and have had 2 others including the HD) and other Line 6 amps, yes this is normal.
  • 1
#4 irobot
irobot
  • 7 posts
Posted 03 June 2013 - 05:02 AM
Thanks for the responses.
This amp sounds spectaular, by the way. Doesn't have all the high-tech whiz effects which can cause headaches . . Just great sounding reverb.
-Mike
  • 1
#5 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 03 June 2013 - 05:30 AM
-Mike
yeah man. i remember testing one at gc. didn't have the cash then, if i did it was coming with me!
I'M SO HAPPY!
#6 gubble
gubble
  • 2 posts
Posted 10 June 2013 - 04:05 AM
Hi - I've also recently found a Duoverb Head and a 4x12. Like new got a unbelievably good deal on it.
The volume thing appears to be perfectly normal.
Loving the sound of the amp - it's fantastic for live work. I wanted a half stack setup, which would cope with venues from small pubs up to larger clubs.
It didn't howver come with the Amp 1 / Amp 2 switch - which i'd really like to find.
#7 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 10 June 2013 - 05:49 AM
it didn't however come with the Amp 1 / Amp 2 switch - which i'd really like to find.
can;t you use this?
http://line6.com/footcontrollers/
I'M SO HAPPY!
#8 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17814 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 10 June 2013 - 06:02 AM
you can use the current FBV MKII (or its earlier non MKII version) which would do alot more.
I think it did come with the amp 1/2 switch, but you'd likely have a hard time finding the original...
however, i believe that it was just a standard latching footswitch, so you should be able to use many alternatives.
#9 gubble
gubble
  • 2 posts
Posted 10 June 2013 - 06:47 AM
Thanks guys - i'll have a look around on ebay etc and see what i can find - might even try a standard 2 button switch.
I have the FBV Express which does 99% of the features the amp has just not the Amp 1 / Amp 2 bit - which i love using for a boost on lead tones.
