chiolas Posted May 13, 2014 Share Posted May 13, 2014 Hello, Just bought my HD500x a couple of hours ago. I don't know what I did, but the expression pedal doesn't work anymore. Can I reset the to factory settings or something ??? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted May 13, 2014 Share Posted May 13, 2014 the expression pedal doesn't automatically work on every preset... its possible you simply changed to a preset that is not setup to use the pedal.... or perhaps you've updated the pod and need to calibrate it? 1 Quote Link to comment Share on other sites More sharing options...
chiolas Posted May 13, 2014 Author Share Posted May 13, 2014 Guess not. Doesn't even work as a volume pedal or anything at all in any preset. I'll try do check that calibration thing out Quote Link to comment Share on other sites More sharing options...
chiolas Posted May 13, 2014 Author Share Posted May 13, 2014 That's right, I just did the calibration, and I can't get to the 0 value. It's 255 toe position and the least I can get is 30 at heel position... Quote Link to comment Share on other sites More sharing options...
Palico Posted May 13, 2014 Share Posted May 13, 2014 If you have downloaded the HD500 Edit. Checked the controller min value. It sets that funny depending on what the value of hte effect at the time of assigment. That has caught me a dozen times. Not sure that's you issue but worth checking. Quote Link to comment Share on other sites More sharing options...
edstar1960 Posted May 13, 2014 Share Posted May 13, 2014 That's right, I just did the calibration, and I can't get to the 0 value. It's 255 toe position and the least I can get is 30 at heel position... I had problems setting the calibration on my HD500 expression pedal - never seemed to want to register the max 255 or the min 0. But I discovered that if I gently pushed it to toe and gently returned it to heel that it would recognise and reflect the max 255 and min 0 values during the calibration process - but if I pushed hard on either extreme then I could never get it to reflect 255 and 0. Hope that helps! Quote Link to comment Share on other sites More sharing options...
duncann Posted May 13, 2014 Share Posted May 13, 2014 I had the same problem as edstar1960. When calibrating the pedal the toe position would always go to 255, but the heel position would only go as low as 45. After a few tries of this I tightened the pedal resistance and cleaned the area around the pedal (including the hole underneath) of any possible dust (I remember reading somewhere that the pedal is optical). And not pushing hard on either extreme as edstar1960 said is also a very good tip. It now works perfectly from 0 to 255. Quote Link to comment Share on other sites More sharing options...
chiolas Posted May 13, 2014 Author Share Posted May 13, 2014 Well, I think I solved that issue shortly after my last reply. I don't know how. Hope it does't happen again. :D Quote Link to comment Share on other sites More sharing options...
CDilworth Posted January 23, 2019 Share Posted January 23, 2019 Hod do I do "the calibration thing"? Quote Link to comment Share on other sites More sharing options...
Eemelamsi Posted January 24, 2019 Share Posted January 24, 2019 8 hours ago, CDilworth said: Hod do I do "the calibration thing"? Check the manual. There should be a step-by-step guide. Or google it. Quote Link to comment Share on other sites More sharing options...
bjnette Posted January 28, 2019 Share Posted January 28, 2019 Quote Link to comment Share on other sites More sharing options...
